Mbox and Digi Core Audio driver causing freezes
I've been having an intermittent problem with the mbox that recently got quite bad and now seems to happen all the time. I boot the mac with the Mbox plugged in, and it lights up happily. I can switch from Mic/Line/Instrument, switch mono on and off, switch phantom power on and off and all seems dandy. When I start Pro Tools or the Core Audio driver, the software simply freezes and hangs straight away. It doesn't stop the computer doing stuff, I can still run lots of programs and things on top, but no Pro Tools and no audio out the M-Box from Core Audio.
The worrying bit is that the Core Audio Driver/Pro Tools (whichever I'm trying to run) refuses to force quit, even when I shut down the computer and I have to do that thing where you hold down the power button until it shuts itself off which canh't be healthy - especially as Pro Tools doesn't let you dismount external drives if it's running. My system details: 1.5 Ghz Powerbook G4 running OS 10.3.6 512 MB of RAM 2 Firewire drives (1 on the 400 bus and one of the 800 bus) but I've tried disconnecting them and the problem still occurs. I normally also have an MT4, iLok and Logic dongle on a UBS hub (the Mbox has full use of the other USB port on the powerbook) and I've tried disconnecting everything but the Mbox and the problem still occurs. Any hints would be welcome. Cheers, Matt |
Re: Mbox and Digi Core Audio driver causing freezes
I run the exact same laptop with an mbox. i have not upgraded to 6.4 yet. although i have only had it a week i came accross a problem where pro tools froze while recording.
i shut off wireless airport, bluetooth, and battery calculator. it hasnt hapened since. im not sure if it is related but you might want to try |
I tried that and it didn't seem to work... I'm worried now because around the time it went wrong I had been using other people's equipment on my Mac (a MOTU 896 HD and a Tascam USB hardware controller) and I'm worried there may be a driver conflict or something. It sounds as if the Mbox isn't getting adequate power... I may end up phoning Digi at this point. I really want Pro Tools back!
1. Uninstall.
2. Restart 3. Remove any trace of Digidesign components (search for it). 4. Restart 5. Reinstall. 6. Restart. 7. Repair Premission.\ 8. Restart. Check for changes. sometimes reinstalling just "fix" it.
Just wanna do music, RA. |
I seem to have sorted it. Did an archive and install from some borrowed system disks, then took it back up to 10.3.6 with a combo update, completely wiped PTLE then reinstalled it. Working well now.
since i download digi core audio manager 6.5.2,
a lot of problems i used to have with core stop.
so what |
Digi Core Audio Driver | nate9 | macOS | 3 | 03-23-2013 06:43 AM |
Core Audio v7.4.2 Driver freezes Itunes 8.2 and will not play in quicktime v7.6.2 | 852 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 07-05-2009 09:30 PM |
MBox2 Core Audio Driver causing programs to hang | Chri | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 10-29-2007 07:11 AM |
Digi ....Core Audio Driver | archtop | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 04-30-2003 07:30 AM |
Bug in Digi Core Audio Driver? Driver update coming? | mgbasinski | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 04-10-2003 08:59 PM |
