Old 08-14-2008, 08:25 AM
15yearsonptools 15yearsonptools is offline
Default MIC Pre control with MIDI
Question about MIDI mic pre control.
I have three rooms sharing one 8 channel Grace mic pre. I'd like to be able to switch (easily) which system is controlling the mic pre. I thinking either a analog switch (I haven't been able to find a pre made midi switch, but I'm pretty sure I could McGyver something) or something fancy from 'Midisolutions.com'. The guy from MIDI solutions has asked if there is any reason the MIDI output from all three rooms should not be connected all the time. Does anyone know if this will be a problem? Or if anyone has a smart idea..
thanks
Old 08-14-2008, 03:47 PM
Rick Sanchez Rick Sanchez is offline
Default Grace Control
I don't know how the Grace midi interface works, but if you can select the channel that's controlling it, you could put each ProTools system on a different channel and just select which one you want to control it. There are any number of midi routers out there. I've always had good luck with the MOTU products.
Rick Sanchez
http://www.posthastemedia.com
MacPro 2x2.66 GHz Dual Core "WoodCrest"
Mac OSX 10.5.8 / 4 Gig Ram
ProTools 8.0.4
Digidesign/Magma PE6NE-I upgraded 6 slot expansion chassis. (Host card in Slot 2 of MacPro)
HD3 Accel
BlackMagic Decklink Studio 2 (In Slot 3 of MacPro)
SurCode / Dolby Media Meter 2
Izotope RX2 Advanced / Sonic NoNoise
Waves Platinum 7.x / Serato PitchnTime
Melodyne Studio / Altiverb XL / Speakerphone
KOMPLETE 7
EQuality / Massey L2007
TC MasterX
Old 08-14-2008, 04:06 PM
Mixchump Mixchump is offline
Default
Not knowing anything about how the protocol is implemented... I wonder what would happen if you just merged all three inputs, and then multed all three outputs. Ideally, if all three PT systems were set for 'Retain Current Settings', then each PT system would be 'learning' the settings from the Mic Pre, even if someone in another room was moving the gain up or down...
That would be ideal, no?
I have 3 Grace Design 802's and I love the heck out of em'
Cheers, eh?
Old 08-15-2008, 02:34 PM
Default
Yes, but I'm worried about accidental adjustments happening. If I wire them all up at once accidents would be possible. I've put a bid on ebay for a MIDI patchbay which I think will be just the right thing. Thanks for the input
Old 08-15-2008, 02:35 PM
Default
the problem is that the mic pre responds to only one MIDI channel
HTML code is On
midi issue- can see midi signal but cant's control Xpand2 macroniche Pro Tools 10 1 08-02-2012 01:16 AM
Pro Control mapping for midi control? michael c ProControl, Control|24, Command|8 0 04-06-2007 01:36 PM
Evolution U-Control midi control surface eddie v MIDI 0 03-22-2004 04:53 PM
MIDI Machine Control out of control zenbarai Post - Surround - Video 3 04-19-2002 08:08 AM
Control PT recording features via MIDI from an extenal MIDI device Montxo MIDI 3 05-05-2001 09:05 AM
