Old 12-05-2001, 04:11 AM
gerax gerax is offline
Default Breakout Cable
Hi
Anybody knows if Digi (or anybody else) is making a longer breakout cable to connect the PCI card to the box of 001? It would be usefull, since my new setup is quite noisy and i'd like to put it a few meters away from my monitors. [img]images/icons/smile.gif[/img]
L.G.
Old 12-06-2001, 01:31 AM
Mr_Seven Mr_Seven is offline
Default Re: Breakout Cable
Do a search of this forum first. It's been discussed and a manufacturer has been identified that you can order from.
Darren Valen
Cyberdream Studios
Old 12-06-2001, 02:44 AM
English Jim English Jim is offline
Kept a copy of this from a post a while back.
"Cable Extension Success!!
I, too longed to move my noisy Mac into an enclosed rack away from my mixing environment, but was told by Digi Tech Support that a longer cable was not available and if I obtained one on my own, it wouldn't be supported. When I said I'd like to take my chances and asked for a spec on the unusual connector so that I could try to obtain a 3rd party cable, the technie said he didn't know and had no way of finding out. (Ahhh, "service.")
So, I did a little hunting online and ID'd the connector on the Digi001 I/O cable as a rare SCSI-2 connector known as a "micro-centronics 50" (sometimes called a "mini-centronics" or a "HPCN50"). More surfing turned up CS Electronics, a supplier of custom cables in Irvine, CA. For $47.50, they made me a 10-foot replacement cable, which I had in my hands within 48 hours!! Great quality, too.
Have been using it with my Digi001 with no ill effects or timing errors. Don't know if cable lengths longer than 10' would cause the problems that Digi cautions against but, for me, it was worth the shot and it paid off -- no thanks to DigiDesign.
Contact CS Electronics at (949) 475-9100, or "http://www.cselex.com" or [email protected]. <<<
Obviously, you are on your own if you do what this guy did. "
Hope this helps
...don't you boys know any nice songs?
Old 12-06-2001, 06:52 AM
Thanx guys, as always good infos from the DUC!!!
L.G.
Need Breakout Cable for MboxPro 3 nhmorgan 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 03-09-2013 12:36 PM
Mbox Pro 3 Breakout Cable nhmorgan 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 03-09-2013 11:33 AM
Need replacement breakout cable!!! kornrox593 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 11-11-2012 11:30 AM
MOBOX 3 PRO Breakout Cable SimonBarSinister 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 13 12-22-2010 08:23 PM
how long is the pci to breakout cable? theom 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 8 01-23-2001 06:57 AM
