Old 05-19-2018, 09:51 AM
PatrickCusack PatrickCusack is offline
Default S6 Softkeys
Are there soft key functions that represent the workstations? In my master module, I would like to use one of the two soft key panels as my workstation list and the second as my list of layouts. I can locate the layout recall in the Surface section of the soft keys, but I can't find a similar workstation recall. Does it exist?
Old 05-20-2018, 11:54 AM
creativecontrol's Avatar
Default Re: S6 Softkeys
Greetings,
Workstations can only be accessed from the master module touch screen or via the master module soft keys by pressing the WS button. Track and Meter Layouts can be accessed anywhere on the soft keys including by holding SHIFT on a fader module while pressing “/“ from the numeric section of the automation module which will access the pre-programmed list of track and meter layouts on the user pages. You can easily modify these to show more track than meter and even span pages. Since these occupy the automation module soft keys you can simultaneously access workstations on the master module and layouts on the automation module.
best,
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Old 05-22-2018, 06:50 AM
Thanks. Jeff. Your last suggestion was an original option. The user has other uses for the bottom automation controls. Thanks.
Old 05-22-2018, 08:31 AM
No problem. Here's a few more ways to address soft key customization:
(1) Modify one of the QuickJumps. A QuickJump is leveraging SHIFT modified 10 key numeric switches on the automation module. There are many pages nested under each of the 4 quadrants (2 each on Master Module and Automation Module) for Automation, Editing, Management and Monitoring for example. For each QuickJump, simply choose the desired page for each of the 4 quadrants to program to a single jump. More information can be found in the S6 Operation document page 72:
https://www.dropbox.com/s/pfvnwemqbt..._18.3.pdf?dl=0
(2) Go full custom. Create completely custom soft keys to address operator needs by using the EuconLayouter app by SonicMonk:
http://www.sonic-monk.com/euconlayouter/
Hope this helps.
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Old 05-23-2018, 04:32 AM
mattrixx mattrixx is offline
Hope this helps.
Jeff
Oh wow.... I wish this was available for S3 Dock and Control...
Matt McKenzie-Smith
mattrixx.net
SourceConnect - mattrixx
AVID Collab user - mattrixx
MacStudio Ultra / LogicProX / IzotopeRX10+ / SourceConnect / MelodyneStudio5 / WAVES Mercury / NI KompleteUltimate / ProToolsUltimate / RME UFX, UFXII, Babyface / AVID S3 + DOCK / Barefoot MM27 gen2 / Barefoot FP01
S6 Softkeys Scope PatrickCusack Avid S4/S6 2 02-28-2018 08:09 AM
Pro Tools 18.1 Softkeys EddieJones Avid S4/S6 5 01-31-2018 04:02 AM
16 Softkeys not active Moviesound Avid S1, S3, Dock and Control App 54 10-23-2017 02:56 PM
SoftKeys customizing - XML OvD Avid S1, S3, Dock and Control App 2 08-17-2016 02:32 AM
C|24 and PTHD softkeys fakir_cz ICON & C|24 4 12-01-2011 06:54 PM
