Does it matter what x79 board I pick?
I'm planning on grabbing an asus p9x79 LE with a 3820 will I pass with it? Some people seem to pick a more expensive version of this board.
Re: Does it matter what x79 board I pick?
One of the diffs is if you need firewire...like me...so the Asus x79 Sabertooth is what I went with, and it works great running my Tascam DM4800 and PT 10.3.3 in native mode. It's the Mobo i/o options you want to investigate including what kind of Ram you want to spec.
My day job: Wilson Dyer MPSE Sound Supervisor: NCIS Los Angeles, CBS Television |
Yeah I think one was dual memory and another was quad channel - If I remember right
I was looking at the same P79 board as well I think the main differences was the USB 3 also - which u want
I can't comment on the P9X79 LE version or any of the more expensive versions of the P9X79, but I have the basic P9X79 and it works very well. The firewire has a VIA chipset though, so you may want to get a PCIe card with a TI chipset if you plan on using firewire devices. I do not use anything firewire.
Pro Tools HD Native 2023.12 | HD Omni | iMac Pro 10-Core 3.0 GHZ - 64 GB - 2 TB - Vega 56 | Ventura 13.5 | Sonnet Echo Express SE II for PT HD Native PCIe and UAD 2 Quad PCIe card | Avid Dock and S1 |
Never know about that - via chipset. - I'm running A Gigabyte GA-x79-ud5 with that via chipset - I have a Sig card with those TI chipsets but its running pretty solid on 10.8.2 - so I don't even have it installed
U never know what u will get
Pro tools 10.3.2 freezes You pick a plugin doesnt matter! | shamanrock | Windows | 21 | 02-20-2013 12:32 PM |
If you had to pick.. | IneedaFATBLUNT | Tips & Tricks | 11 | 04-06-2011 11:32 AM |
If you had to pick, Which one would it be???? | M2E | Pro Tools TDM Systems (Mac) | 11 | 05-04-2008 09:51 PM |
BOARD TECH NEEDED to service Amek Matchless board | audio[LAB] | General Discussion | 4 | 01-31-2007 11:17 AM |
Trying to pick a cd-rw | guitarboy | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 08-22-2000 07:19 PM |
