Old 10-21-2011, 07:38 AM
bobo mark bobo mark is offline
Default Can old Accel TDM system handle 32bit float file format?
When i click the avid store, it clearly said the feature is included. but i want to find one more reason to upgrade.
I mean current Accel TDM system can record and mix 32bit float file format??? but the TDM is actually 48bits fix system?
thanks
Regards
Bobo
Old 10-21-2011, 07:48 AM
marietto81cs marietto81cs is offline
Default Re: Can old Accel TDM system handle 32bit float file format?
Recording bit depth and INTERNAL MIXING bit depth are two different things.
Old 10-21-2011, 07:57 AM
So... Does it works?
Regards
Bobo
Old 10-21-2011, 11:27 AM
PaulV's Avatar
PaulV PaulV is offline
Yes. 32 bit float audio file support works with any hardware (built-in, Native, HD). As marietto81cs mentions, it's separate from internal processing bit depth, so your hardware will continue to operate at the same resolution as before.
Cheers,
Paul Vercellotti
Avid Engineering
Recording: 24bit vs. 32bit float WombatStudio.Org Tips & Tricks 55 10-05-2014 03:41 PM
How do I know my Pro Tools 10 using AAX 32bit plugins format. ak11_lin Pro Tools 10 3 09-17-2013 07:36 PM
32bit float (16.8)/(.24) import PROBLEM donrey Pro Tools TDM Systems (Win) 14 05-20-2006 12:05 PM
The 32bit float advantage ptnerd Pro Tools TDM Systems (Mac) 22 11-19-2005 10:26 AM
24Bit Fixed Plug-in Buss Vs 32Bit Float Matt_G Pro Tools TDM Systems (Mac) 20 08-02-2004 07:29 PM
