Can old Accel TDM system handle 32bit float file format?
When i click the avid store, it clearly said the feature is included. but i want to find one more reason to upgrade.
I mean current Accel TDM system can record and mix 32bit float file format??? but the TDM is actually 48bits fix system? thanks
Regards Bobo |
Re: Can old Accel TDM system handle 32bit float file format?
Recording bit depth and INTERNAL MIXING bit depth are two different things.
So... Does it works?
Regards Bobo |
Yes. 32 bit float audio file support works with any hardware (built-in, Native, HD). As marietto81cs mentions, it's separate from internal processing bit depth, so your hardware will continue to operate at the same resolution as before.
Cheers, Paul Vercellotti Avid Engineering |
Recording: 24bit vs. 32bit float | WombatStudio.Org | Tips & Tricks | 55 | 10-05-2014 03:41 PM |
How do I know my Pro Tools 10 using AAX 32bit plugins format. | ak11_lin | Pro Tools 10 | 3 | 09-17-2013 07:36 PM |
32bit float (16.8)/(.24) import PROBLEM | donrey | Pro Tools TDM Systems (Win) | 14 | 05-20-2006 12:05 PM |
The 32bit float advantage | ptnerd | Pro Tools TDM Systems (Mac) | 22 | 11-19-2005 10:26 AM |
24Bit Fixed Plug-in Buss Vs 32Bit Float | Matt_G | Pro Tools TDM Systems (Mac) | 20 | 08-02-2004 07:29 PM |
