Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools 2020
Old 11-15-2020, 04:02 PM
mattrixx mattrixx is offline
Default ProTools Ult 2020.11 Full scale noises
Since updating to 2020.11 I have been getting full scale noise/feedback, when launching sessions, activating or deactivating AUXs etc.
It's bloody scary to be honest and I don't want to break anything in my monitoring chain.
I use many AUXs for routing things like SourceConnect, SourceNexus, Izotope RX monitor and Soundly.
This never happened with any previous versions and this is really bloody annoying. What the hell has changed to be causing this??
Regards,
Matt
Matt McKenzie-Smith
mattrixx.net
SourceConnect - mattrixx
AVID Collab user - mattrixx
MacStudio Ultra / LogicProX / IzotopeRX10+ / SourceConnect / MelodyneStudio5 / WAVES Mercury / NI KompleteUltimate / ProToolsUltimate / RME UFX, UFXII, Babyface / AVID S3 + DOCK / Barefoot MM27 gen2 / Barefoot FP01
Old 11-15-2020, 04:16 PM
jeam25's Avatar
jeam25 jeam25 is offline
Default Re: ProTools Ult 2020.11 Full scale noises
Hi don't have a clue but comes to mind the most simple thing delete prefereneces. Did you ?
Mac M1 Studio Ultra - Sonoma Beta OS
Avid Carbon Interface
Protools Ultimate
Old 11-15-2020, 04:21 PM
No, I did not delete preferences. To be honest, all is working well other than the routing bursts on launch, activating and de-activating of AUXs (which settles straight after and I can de-activate and re-activate without bursts after the session settles.)
Matt McKenzie-Smith
mattrixx.net
Old 11-15-2020, 04:23 PM
jeam25's Avatar
It worth try unless you have complex routing set right now. Maybe exporting IO settings first ?
Protools Ultimate
Old 11-15-2020, 04:26 PM
Yes, might give that a try, as most of the routing is via SourceElements products.
Matt McKenzie-Smith
mattrixx.net
Old 11-15-2020, 07:36 PM
unkJE's Avatar
unkJE unkJE is offline
If you have a VST host, until there’s a fix, protect your gear and ears:
https://freevstplugins.net/cerberus-...ice9-automute/
"Ice9 Automute’s soft-muting function will begin to attenuate the gain before a single sample over the threshold has passed. Instantaneous radical attenuation will occur if the threshold is exceeded by a severe and potentially dangerous amount.
This update features an increased threshold range for matching levels commonly used with digital/analog hybrid signal chains. It also fixes an important functional issue for Windows users, and introduces internal improvements for Mac users.
Changes in Ice9 Automute v1.1
Increased threshold range to -12dB, adjustable in 1dB increments.
Windows: auto reset was not working on some systems. Fixed.
OS X: Recompiled with Apple LLVM C++ compiler (brings stability and performance improvements)."
More info:
https://www.pro-tools-expert.com/log...-ice9-automute
Pro Tools Studio 2024.3 * SSL UC-1 * Digidesign Command 8 * TECH 21 SansAmp 2.0 * Xvive U3 2.4Ghz Wireless Microphone * Shure SM57 & Rode NT2-A * Fender 30 & Champ 12 valve amps * M-Audio Axiom Pro 49 * PreSonus Speakers & Monitor Station V2 * Lenovo W520 laptop Type 427637U (32 GB RAM) with extra-Ports Dock + SSDs: 2 @ Samsung T5 + 1 @ Samsung T7 * 3 Screens: 15.6” Laptop + 24” BENQ GL2450-B + Samsung 27” CT550 curved Monitor * best Wife!
2018.7 Full Scale Noise Bursts laki Pro Tools 2018 4 08-14-2018 06:10 PM
random full scale noise in edited tracks!? digidesigner Pro Tools TDM Systems (Win) 1 06-01-2011 10:04 PM
Full scale volume when moving clips Frank Kruse Post - Surround - Video 7 05-15-2008 03:49 AM
001 / PT6.4: Full scale noise instead of audio? timdog 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 04-09-2006 08:10 PM
888|24 clips at or near 0 dB Full Scale! Corey Shay Tips & Tricks 4 02-18-2000 02:14 PM
