PTHDN does not recognize 2nd Omni interface
Quick preface
Thru a weird set of circumstances I ended up with a second Avid HD Omni which I am trying to use as a second I/O device so I can increase my I/O count. But for some reason (probably something I am missing because until now I have not used multiple I/O units ) I can not get both Omni's to show in the the I/O window . And In the Hardware Tab it lists only the #1 Omni As per the manual The #1 Omni Primary Port is connected to the DigiLink Mini Port #1 on the HD Native card The #2 Omni Primary Port is connected to the Expansion Port on #1 Omni The Loop Sync " Out" on #1. Omni is connected to Loop Sync "In" on #2. Omni Loop Sync "Out" on the #2 Omni is connected to Loop Sync "In" on the #1 Omni Both Omni's appear to be running firmware version 2.10 (I think) because the both the Primary 1- 16 and the Expansion 17-32 show up in the digitest as version 2.10 But the info page only shows the the serial # for the #1 Omni no matter if I select Primary or Expansion. ????? Also either Omni's will run a session just fine ???? but still only shows the I/O matrix for one Omni ??? I tried Holding down the N key and launching PT but can only choose HD Omni #1 or PT Aggregate ? So I have tried trashing preferences and also downloading HD drivers with only the #2 Omni powered on NADA Any suggestions other than starting a support ticket ? Thanks Kev,
System : Studio - Avid Carbon interface , PT Ultimate 2023.12 Mid 2020 (intel) iMac 27" Ventura 13.2 .1 Mobile - 2021 14 " MBP M1 Pro PT Ultimate 2023.12.1 Sonoma 14.4 Enjoy the Journey.... Kev... |
Re: PTHDN does not recognize 2nd Omni interface
Pro Tools only supports one Omni interface. Been that way forever and is well documented/discussed in the past on DUC.
Well Dam Sam that's the pits
Yep, it’s frustrated lots of people. I suspect it’s more just not worth Avid’s time doing the engineeering vs. a more malicious deliberate reason to force people to buy a HD IO or MTRX.
And I am certainly no engineer or code writer But having set up this dual Omni situation, it appears to be only in the software coding ( the validity of which I am not knowledgeable enough to judge) Because as I noted the either hardware unit runs fine with both Omni's connected to the system.
System : Studio - Avid Carbon interface , PT Ultimate 2023.12 Mid 2020 (intel) iMac 27" Ventura 13.2 .1 Mobile - 2021 14 " MBP M1 Pro PT Ultimate 2023.12.1 Sonoma 14.4 Enjoy the Journey.... Kev... Last edited by K Roche; 01-27-2019 at 07:48 AM. |
PT won't recognize my HDN+omni/IO | tubiux | Pro Tools HDX & HD Native Systems (Mac) | 20 | 10-08-2014 12:47 PM |
Audio Midi Setup doesn't recognize io on Avid HD Omni Thunderbolt | MJarzabek | Pro Tools HDX & HD Native Systems (Mac) | 5 | 10-10-2013 07:36 AM |
Pro Tools won't recognize Omni, digitest crashes on launch | dj_grimmace | Pro Tools HDX & HD Native Systems (Mac) | 10 | 08-22-2013 01:09 PM |
pro tools 10 doesn't recognize omni hd | ilvecchio | macOS | 4 | 11-03-2012 07:42 PM |
PRO TOOLS 10 + HD2 + 96 IO interface not recognize | eliomusik | Pro Tools TDM Systems (Mac) | 14 | 09-28-2012 11:34 AM |
