Old 02-10-2012, 02:53 AM
EMXPRSS EMXPRSS is offline
Default Protools 9/ rme distortion after 10 seconds of recording
Hi Everyone,
Im running Protools 9.0.6 with Rme babyface(latest driver) with on macbook pro 10.6.8. The problem is when im recording single into Protools the recording suddenly starts getting distorted. It sounds like a bit crusher with delay effect. Then i change the buffer size and it goes away and after recording 15-20 second it comes back again no matter what the buffer size is (32 to 1024) It doesnt happen all the time. When this occurs i literally have no plug-ins on the channels so i dont think it's a cpu issue. All of my drivers are up to date, I tried both usb inputs on the mac. Thing is it doesnt happen all the time, it happens for a day or two then ıt goes away. What could be the problem?
Thanks in advanced for any help.
Old 02-10-2012, 11:20 AM
Diccer Diccer is offline
Arrow Re: Protools 9/ rme distortion after 10 seconds of recording
I'd email RME tech support. They're pretty good about getting back, and best of all- it's free.
Does your MacBook Pro have a mini pcie slot? Because RME has a card for that..
My only experience is with the hdsp aio, so I can't be more help..
Just Run Pro Tools as a Rewire Slave/Run Parallel.. its easier than you think. Example- RME TotalMix and the IAC Midi Driver
http://duc.avid.com/showthread.php?t=313749
Old 02-13-2012, 02:07 AM
Default Re: Protools 9/ rme distortion after 10 seconds of recording
Hi Diccer,
I did e-mail them but the problem only occurs within Protools. I also tried it out with Reaper, Logic and didnt have the any problems.
Old 02-17-2012, 01:45 AM
The problem was recording in to internal hard drive. Sometimes i go out for field recording and i did not realize recording into internal drive would cause this.
ProTools Recording Distortion HKD126 Pro Tools M-Powered (Mac) 1 02-11-2012 02:34 PM
No playback on recording over 30 seconds ditto Pro Tools SE and Essential (Win) 0 12-31-2011 04:27 PM
Recording just stops after 30 seconds rickoverwater Pro Tools M-Powered (Win) 7 07-12-2010 01:27 PM
Protools stops Recording every 15 seconds Toriano Pro Tools TDM Systems (Win) 0 02-06-2010 05:15 PM
4 seconds before recording Fokke van Saane Pro Tools TDM Systems (Mac) 19 08-08-2002 06:46 AM
