Time Adjuster plugins NOT working on Instrument Tracks!
Hello everybody,
I'm new to Pro Tools LE and I need to get a job done on it. I composed a piece of music and now I'm at the mixing stage where I encountered the following issue. As I used some latency introducing plugins and LE doesn't have automatic plugin delay compensation I'm supposed to delay it manualy using the Time Adjuster plugin. However this plugin doesn't work at all when used on an Instrument Track! Why is this? It only works when used on a regular Audio Track. I discovered that it doesn't work by printing (recording) on a new track and there is no delay introduced by Time Adjuster! Could you tell me if that's a known issue on Pro Tools LE and also how to solve this problem? Thank you in advance, Horea |
Re: Time Adjuster plugins NOT working on Instrument Tracks!
Time Adjuster? Apparently it is for video, DVDs. You might be thinking of Time Shift? It works only for audio tracks. Instrument and midi tracks and audio tracks could be nudged to compensate for latency.
OSX10.6.8, 1st gen Power Mac, PT8.0.5, Mbox2 |
Use Time Adjuster to delay other tracks by the same amount (of samples) as that introduced by the plug-ins. It does not work by bringing track playback forward!
You can save some CPU overhead by bussing tracks that need similar PDC so fewer instances of Time Adjuster are needed. It does work on instrument tracks but be aware that the VI will have an inherent processing delay between the midi note and audio playback. I usually print the audio and nudge it back into line with the midi data. http://www.myspace.com/philogg |
I only googled Time adjuster, coming up with nothing in reference to Protools. My bad I have learned this one too.
Working with Instrument tracks with MPC in PT8 | cyba | Virtual Instruments | 0 | 10-15-2011 10:47 AM |
PTLE 7.4 and "instrument" plugins not working!... still | GrandPianoTracks | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 05-27-2008 07:53 AM |
Time adjuster plugins | pingu | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 05-12-2008 06:25 AM |
Can You Use Plugins on Instrument Tracks? | fasttraxx | Virtual Instruments | 8 | 12-26-2007 04:53 PM |
Playing 2 instrument tracks at the same time | Ford | Virtual Instruments | 2 | 09-15-2006 02:59 PM |
