OK to change bit rate for an existing session?
I'm currently always recording in 24 bit/44.1 kHz.
But I have some older projects that were recorded in 16 bit/44.1 kHz. Is it OK to change those to 24 bit/44.1? I have additional work to do on these sessions. I tried searching for this on this forum, but the answers I found all seemed to include the user wanting to change the sample rate as well (which I don't want to do). |
Re: OK to change bit rate for an existing session?
You are asking about the bit depth, not really the the bit rate (OK the bit rate changes with bit depth art fixed sample rate, but still...). Which may be why you are not finding anything. Folks do this all the time, Save Session In...
There really is no downside (small increase in storage space) all upside in working at higher bit depth. If sending back to 16 bit later you get to decide when/how things are dithered back at 16 bits. But why are you working at 24 bit fixed? Why not have all your sessions in 32-bit float? |
Thanks for your reply.
OK--then let me rephrase the question: Should I change my existing 16-bit sessions to 32-bit float? Last edited by dg27; 10-20-2019 at 04:48 PM. |
Yes. It's fine. I often change my 32 bit float sessions to 24 bit right before I need to create temp files to send to a picture editor. And then I change it back after creating files (it's so consolidated files are created as 24bit and not 32 bit float)
Pro Tools Ult 2024.3, HDX 2, MTRX/SPQ, RME BBF Pro + MADIface Pro • S1 x 2, Fire HD10 + Max11, Dock, iPad Air5 • Mac Mini 14,12, 12 core, macOS 13.6.5 • RAM 32GB, SSD 4TB, GPU 19 core • QNAP TVS-872XT 148TB TB3 |
Thanks.
Yes!
No need to "Save Session Copy In..." - you can change bit depth in your session any time you want in the Session Setup Window. Existing audio will remain at previous bit depth but all newly generated audio (via recording, commit, bounce) will be at the new bit depth.
Can I change the sample rate of an existing session? (PT9) | bicasaur | macOS | 2 | 07-28-2013 01:40 PM |
Change SR on an existing session? | GrievousAngel | Pro Tools 9 | 7 | 12-30-2011 09:01 PM |
How to Change A Session's Sampling Rate | homegirl | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 07-17-2007 01:29 AM |
Sample rate change during session? | JonMitchell | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 10-02-2005 10:47 AM |
Changing the sample rate of an existing session | Torgo | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 12-12-2004 08:52 PM |
