Old 11-18-2005, 11:39 AM
CanadaMusic CanadaMusic is offline
Default Re: Poor Performance in 7.0 Petition - Please Register
Just a note to wreckthis place :
The DAE setting should be left at 2 except for special circumstance. Any setting other than 2 has been known to cause stability issues.
Old 11-18-2005, 12:29 PM
wreckthisplace wreckthisplace is offline
damn.
just realized that i can't open new session files with an older version of pro tools.
i have something that i'm working on. i may need to bite the bullet and deal with the major issues as i'm working.
unless there is a way to import session data from pro tools 7 sessions into pro tools 6.9.2. anyone?
Old 11-18-2005, 12:33 PM
whtrabit whtrabit is offline
tried i with the buffer size at max
set to 2 processors at 85% and sometimes %90 (thats all i can go to, i don't have a %99 option maybe because i'm using reason as well?)
No its because you are using a Mbox.
jimmy
15" Macbook Pro R 2.6 i7 Quad/16GB RAM/OS X 10.10.5
27" iMac 2.8 i7 Quad/16GB RAM/OS X 10.10.5
Studio One 3/Reason 8/Live 9/Logic Pro 9/Main Stage 3
Old 11-18-2005, 12:40 PM
FSuarez FSuarez is offline
Idem...
iBook 12" OSX 10.4.2 768Mb RAM
Old 11-18-2005, 12:54 PM
phanatik phanatik is offline
Shawn Strong/Abdul-Badi
Digi 002/Pro Tools LE 7.0
Mac OS X 10.4.2
PowerMac G4 dp 1.25/1.5 G RAM
Shawn Strong
Phanatiks Entertainment
http://www.phanatiks.com
  #16
Mac OS X 10.4.2
Shawn Strong
  #17
Old 11-18-2005, 02:10 PM
Loudnoize Ent. Loudnoize Ent. is offline
damn.
WTP... Launch PT7, then "Save Copy In"...5.0 to 6.9.
  #18
Old 11-18-2005, 02:28 PM
Niljam Niljam is offline
Setup:
Mac G5 Dual 2.0 GHz (M9747)
2,5 GB RAM
OSX 10.4.3
Digi002Rack (Power Harness replaced Aug 2005)
Internal, original 160 GB 7200 rpm drive with 2 partitions: one for OS & apps, one for audio
No other FireWire gear connected
USB: Logitech powered hub with Apple Pro Keyboard, Optical Mouse, MidiSport 2x2 midi interface.
Software:
ProTools LE 7.0
Plugins: Digiracks, TRacks EQ, Amplitube LE, SampleTank SE, PSP Vintage Meter, Miroslav Philharmonik, Native Instruments Akoustik Piano, Garritan Personal Orchestra, EastWest Quantum Leap RA + Colossus
(Lots of other unrelated software is installed on this Mac, but I shure hope that doesn't affect PT!)
Issues:
-Very frequent session stops due to sudden CPU spikes, although CPU-meter is running low at average (30%)
-Sessions that played well in 6.9.2 choke i 7.0 (no other plugins than the above)
-Frequent loss of contact with Digi002R, especially when loading/unloading lots of samples into RAM. (This could be the harness again (sigh) or a poor FW-port on the G5, but it seems to happen more often now than before the upgrade)
The most evident difference visavi 6.9.2 are the sudden and unexpected CPU spikes in 7.0 that will stop the session.
I've been using PTLE on Mac for many years so I know and have tried all the usual troubleshooting stuff.
PS: I'm writing a long review article about PTLE7.0 for two major swedish magazines, and I'd hate to say anything bad about my favourite DAW...
  #19
Old 11-18-2005, 02:45 PM
Setup:
You need to remove all 3rd party plug-ins and run Pro Tools. Create a new session -- if it's stable, start adding the plug-ins one by one.
You have incompatible plug-ins.
When I say "remove" I mean take them out of the DAE Plug-ins folder.
Rail
Platinum Samples
www.platinumsamples.com
Engineered Drums for BFD
  #20
Old 11-18-2005, 04:08 PM
Hello Rail,
I am just wondering if you are having any problems with Pro Tools 7 LE under the MAC OS?
If not, I would really appreciate it if you could list the plugins that you are currently using.
Thank you
poor rewire performance swethington 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 09-04-2008 04:13 PM
Poor Performance L-Dogg 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 06-12-2006 02:21 PM
very poor performance gaus 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 17 03-07-2004 06:27 PM
Poor performance with 5.1.1 bstaley 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 14 07-03-2001 09:45 AM
G4 PT 5.0 poor Performance ProTools4 Pro Tools TDM Systems (Mac) 2 02-24-2000 12:58 AM
