Old 03-28-2023, 04:29 PM
noah330 noah330 is offline
Default Anyone Running Ableton Live on HDN Hardware?
I'm collaborating on a project where Abelton is the DAW of choice. I have HDN. Is anyone using this with HDN? Any issues?
Apple M1 Mac Studio (base model)
ProTools Carbon w/SSL XLogic MADI-AX
Instagram:
https://www.instagram.com/sparkletune/
Old 03-03-2024, 06:56 AM
Btboog Btboog is offline
Default Re: Anyone Running Ableton Live on HDN Hardware?
Did you ever do this? We’re there any issues?
Old 03-03-2024, 06:58 AM
tope d's Avatar
tope d tope d is offline
Let me check if I can find similar cases on this…
-Tope
To create a support case with Avid Support, go to https://www.avid.com/learn-and-suppo...-music-support
www.topedomingo.com
Old 03-03-2024, 08:04 AM
Thank you.
Old 04-01-2024, 10:34 PM
tope d's Avatar
Apologies for the delay. I saw a support case with the same inquiry, tech team responded with the following:
We have only tested the HDX and HD Native Thunderbolt, with Avid Audio interfaces. We recommend reaching out to Abelton Technical Support for more information about this.
For other concerns, you may also check out the following channels:
Avid Support Portal: https://csportal.avid.com
Avid Support Code Portal: http://avid.force.com/ASC
Avid Webstore Support: https://www.avid.com/contact-online-store
Pro Tools System Requirements: https://avid.secure.force.com/pkb/ar...m-Requirements
OS Compatibility Chart: https://avid.secure.force.com/pkb/ar...tibility-Chart
-Tope
www.topedomingo.com
Old 04-01-2024, 10:57 PM
Tope
The question was not about interface hardware. And Abelton does not make any Digilink interfaces, and I doubt the OP meant the CoreAudio interface in Abelton Push, they just meant using the Abelton Live DAW with HDN CoreAudio support.
I'm not sure why folks are worried about this. If the HD Driver works and you see the interfaces in AudioMIDI Setup then CoreAudio stuff should work. Just try it. The challenge is all with the HD Driver and it's known issues, inclduing AvidAudioServer misbehaving at times, the need for the correct Thunderbolt expansion dock, etc. but if you have gotten past that to CoreAudio seeing the Digilink interface(s) then you should be set. Nothing here really specific to Abelton
Old 04-02-2024, 12:38 AM
LDS LDS is offline
Ableton Live does have a very ragged history when it comes to Avid's coreaudio drivers. It was basically unusable for years here. I haven't even bothered trying to use it for 4 or 5 years. Last I heard (way back in 2020), Ableton had acknowledged the existence of a bug... but also gave zero indication when or if it would ever be fixed.
Pro Tools Ultimate 2024.3. OSX 13.6.5. Win 10. HD Native. Lynx AES16e. Lynx Aurora 16. i9-13900KF. ASRock Z690 Steel Legend. 64GB Ram. AMD Vega 64. BM Decklink. Dolby Atmos Renderer 5.2. Trinnov D-Mon. D-Command.
Old 04-02-2024, 01:30 AM
I have seen Live running on HDN systems seemingly with no problems, but I was not the user/not my setup. Was this problem changing HW buffer size? Like this… https://duc.avid.com/showthread.php?t=326612
Old 04-04-2024, 03:29 AM
LDS LDS is offline
It may have well been addressed by ableton in recent releases. I haven’t tried it in years, mainly due to the unexpected benefit of being able to keep Ableton and ProTools open at the same time thanks to a second sound card.
The issue was bigger than just sample rate stuff. It was totally unusable and wouldn’t ever play audio.
HDX Hardware and Ableton Live LDS Pro Tools HDX & HD Native Systems (Mac) 11 06-12-2023 02:32 PM
Running Ableton Live and Pro Tools freakhouse macOS 1 03-24-2022 09:43 PM
playing live, ableton live best option? shabbar3 Pro Tools 9 0 07-11-2013 05:22 PM
Digi 003 as hardware control surface for Ableton Live? bentropy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 09-02-2011 08:11 AM
Ableton Live - performing/recording live w/HD3 Surth Pro Tools TDM Systems (Mac) 1 09-11-2006 04:50 AM
