Flanging problem
I’m using a G4 450 with 386 Ram and PT 5.1, 001. I’m trying to use the sends of my 001 to a lexicon MPX 1 for reverb and back in the 001 on an aux track, but when I do, on larger sessions, I get a flange effect. If I don’t use the send, and actually assign the output of the track to go the reverb and back in on an aux track, it’s not there, only when I use the sends…and only sometimes. Any thoughts? Thanks!
Re: Flanging problem
I imagine your hearing a offset being mixed in with the original signal. the reason why you dont hear it the other way is because there is no mixing of signals going on.
anyone else?
http://www.crystalclearrecording.com |
Yes, make sure the return is set to 100% wet and that should do the trick. You may also want to nudge your send track back a few clicks to make up for the delay of going in and out.
That sounds about right! Thanks!
Help: Tracks are flanging and I didn't ask PT to do so | appleaudiond | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 03-07-2011 07:00 AM |
Recording Vinyl into 7.4 - Flanging problem | swamp gravy | Pro Tools M-Powered (Mac) | 7 | 04-17-2009 12:43 PM |
Flanging Question | tomhartman | Pro Tools TDM Systems (Mac) | 1 | 08-28-2003 04:12 PM |
Flanging sound on only 1 midi device | quaz | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 06-03-2002 02:46 AM |
flanging, phasing, and chorus Q | merz | Pro Tools TDM Systems (Mac) | 1 | 11-30-1999 02:18 AM |
