Old 07-07-2020, 08:27 AM
idruijf idruijf is offline
Default I can't see my instrument plug-in but I can see everything else
Hi everyone,
I am just getting starded with midi and I wanted to install some instrument plugins on my keyboard. I already made an new stereo aux input track. I am in my mix window and then I go to inserts A-E. After that I go to multichannel plug-in. At this point I can see alot of different plug-ins expect for the instrument.
The plug-ins I can see are: 'EQ', 'Dynamics', 'Pitch Shift', 'Reverb', 'Delay', 'Modulation', 'Harmonic', 'Ditcher', 'Sound Field' and 'Other'. Beneath those plugins is a line and beneath that line there are the options: 'Avid', 'Two big ears' and beneath that is the option 'Avid Marketplace'.
So I am missing my instrument plug-in and my effect plugin.
How do I fix this? I really want to move on but I am stuck right now.
Cheers,
Ivo
Old 07-07-2020, 08:47 AM
Default Re: I can't see my instrument plug-in but I can see everything else
Hi welcome to DUC
You should get VIs working first on an instrument track. Look for tutorials on YouTube and follow along exactly what they do.
Did you install the AIR instruments using the separate installer? If so what plugins are in the plugin folder on your computer? Look in your Avid.com account for all the plugin installers.
Old 07-10-2020, 04:24 AM
Hi Darryl,
Thanks for your reply. I did not install the AIR instruments yet so I did in the marketplace. Now my problem is solved.
I can move on now thanks!
Cheers,
Ivo
Instrument Plug-ins, Windows 10 Nymeria Pro Tools 12 5 08-28-2017 07:20 AM
AAX Instrument Plug-Ins dropping from Instrument Track stardancer AAX Plug-ins 2 09-12-2015 08:26 PM
Instrument track inactive after removing plug in OTHER than instrument pshammond Pro Tools 12 13 07-25-2015 09:19 AM
Where are my Instrument Plug Ins? Kylehamilton Getting Started 3 12-05-2014 10:38 AM
Using an Instrument Plug-in pedmunds1 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 11-13-2005 07:32 PM
