Old 03-10-2013, 01:12 PM
grayter1 grayter1 is offline
Default 48K Sample Rate Problem
Long time Mac user that recently switched to Window 7. PT10 is running well with all of my music projects which are at 44.1. However, Im working a sound for post project at my day job, and when I try to open a session at home (recorded at 48K), PT will not play, and then forces me to restart.
After restarting PT, the session works fine. I have the same problem going the other way (have to launch the session, close out, then relaunch).
I'm not sure if it's a PT problem or an audio driver issue. I'm using a Focusrite Scarlett 18i6.
I've done some searching, but have found nothing concrete. I'm perplexed, because I don't have any of these issues on my Macbook Pro. I can go between 44.1 and 48k sessions with no issues.
tg
Win 10 Pro / i7-6700K 4.00GHz / GA-Z170X-UD5 / 32 GB / nVIDIA GTX 1050ti / RME BabyFace Pro FS / Yamaha MODX6 / Komplete S49 / Pro Tools Ultimate 2020.9 / Nuendo 10.3 / Reaper 6 / Studio One 5 / Komplete 12
Old 03-10-2013, 02:28 PM
justus1900 justus1900 is offline
Default Re: 48K Sample Rate Problem
Oh Crap, I had this problem but I don't remember how I fixed it, but I do remember that it was part of PC sound card, I change the setting in the sound card and it worked, I hope this at least starts to steer you in the right direction. I remember Start, Control Panel, sound, Playback, right click on the interface and I changed something. Try and play with that.
Producer/Engineer/Musician
RIAA Platinum Sales Award: Lisa Stansfield "Affection"
Main:
Model: Dell Precision T1500 Minitower
OS: Windows 10 SP1
CPU: Intel® Core™ i7-860 (2.8GHz,8MB)*
Memory: 32GB (4 X 8GB)
SATA Internal OS 480GB SSD, Record 480GB SSD, 1TB and 750GB External Glyph GT 050Q 500GB HD
AVID Digi 003 Console x 2
AVID Pro Tools 2019.12
JBL LSR4328P Studio Monitors
Yamaha HS50M Studio Monitors
Portable:
Model: Acer Aspire E5-575
OS: Windows 10 Home 64 Bit SP1
CPU: Intel® Core™ i5-6200U
Memory: 16GB
SanDisk 256GB SSD, 480GB SSD
AVID: Fast Track C400
Pro Tools 12.5.0
Old 03-10-2013, 03:00 PM
Thanks for your help. I'll look into it. I just confirmed that it's not the Saffire driver. I'm able to open a 44.1 and a 48K project at the same time with Studio One, and switch between them. The driver switches accordingly.
I have all of the built in sound card drivers (on the motherboard) disabled, so I'll dig a little deeper.
tg
Old 03-10-2013, 03:08 PM
The error I'm getting is:
Problem detected with audio clock. Check that your clock source and sample rate are correct.
tg
Old 03-10-2013, 08:14 PM
albee1952 albee1952 is online now
Try setting the clock rate before you open Pro Tools. I just spent 2 days with the Antelope Orion(32x32) interface and changing sample rates required opening the session, getting the message regarding the wrong sample rate, closing Pro Tools, then opening it again, then the session. Very annoying!
Old 03-11-2013, 05:24 AM
Agreed. That's what I've been doing. I know it's a Pro Tools issue and not my Scarlett, because S1, Live, and Reaper all switch sample rates between sessions.
Thanks for the replies.
Old 04-23-2013, 09:43 PM
juanonyc juanonyc is offline
I am also having this issue. I just got a Saffire 56. I have a project which is on 44.1k, Mix Control sees it fine. But when I close and open a project in 48k, I get the clock error message. I do a restart of PT and the 48k project plays fine. Close and reopen the 44.1k project. Clock error! I had no issues with this when I used an Mbox. Very frustrating I have to restart PT to open a file.
Old 04-25-2013, 06:28 AM
peter kuchar peter kuchar is offline
What I do to change sample rates is close pro tools, change to desired sample rate, open pro tools, then create a new session at the desired sample rate, change something in that session (I just move the curser) save, close then you can open sessions at that rate without errors. Then just use that session every time you need that sample rate. Create one dummy session for each sample rate you require. Works every time!
Old 02-07-2015, 09:32 PM
philip888's Avatar
philip888 philip888 is offline
Dave did you ever get your Orion issue ironed out?
I have this thing about a month and it has a total PITA.
Gigabyte EX58A-UD3R BIOS FH, Intel Core i7 CPU 980X, 24GB Mushkin Enhanced Blackline DDR3 1600Mhz PC3-12800, NVIDIA GeForce GTX 560, Windows 10 Pro 64 Bit, Pro Tools 12.7
Old 02-08-2015, 10:49 AM
The Weed's Avatar
The Weed The Weed is offline
IIRC, this is SOP for PT and third party interfaces.
Cheers,
non-union national read at a reasonable rate
Demos: brucehayward dot com
Source-Connect: brucehayward
Sample rate problem please help! sixxxstring 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 9 09-23-2008 07:08 AM
Sample rate problem Dr.Marv Pro Tools TDM Systems (Mac) 7 09-16-2008 03:10 PM
Bit Rate/Sample Rate problem? The chipmunks? bspro 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 03-17-2008 05:40 PM
sample rate problem. Help! Ryan Butler 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 11-07-2007 11:23 AM
Sample rate problem sean shannon 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 06-27-2005 08:07 PM
