Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools 2020
Old 02-17-2021, 07:54 AM
srdm77 srdm77 is offline
Default check R128 offline / measure with WLM while bouncing
Hi there,
how can I measure my mix offline? I have a WLM Plus in my Master-bus and tried to see the levels while bouncing offline, but it didn`t work.
Hardware:
Intel(R) Core(TM) i7-3930K CPU @ 3.20GHz
BIOS-Version American Megatrends Inc. 4901, 07.05.2018
24 GB RAM
System-Volume: SSD
Audio-Volume: SSD
NVIDIA GeForce GTX 750 (Driver 27.21.14.6089)
Steinberg UR 22 mkII (USB via Yamaha Steinberg USB AUDIO)
Windows 10.0.19041 Build 19041
ProTool Ultimate 2020.12.0
Nuendo 11.0.0
Old 02-17-2021, 08:03 AM
Default Re: check R128 offline / measure with WLM while bouncing
Originally Posted by srdm77 View Post
Hi there,
Perhaps your WLM instantiation is on the monitor path and your actually bouncing a mix bus? If the WLM is on the path that's actually being bused it should give you a reading at the end of the offline bounce.
http://www.richbreen.com
Mac Studio / Ventura, PT 2023.12.HDX, Avid HD I/Os and Metric Halo ULN8, 3xS1/Dock
Also running a Mac Studio Ultra / Ventura / HDX / MTRX / S6
Old 02-17-2021, 09:04 AM
The WLM is in the bus, I bounce and while bouncing, there is no metering at all in the whole session.
Hardware:
24 GB RAM
System-Volume: SSD
Audio-Volume: SSD
Nuendo 11.0.0
Old 02-17-2021, 09:23 AM
devinemke's Avatar
devinemke devinemke is offline
you need to bounce your mix, then use WLM as an AudioSuite render on the bounced media to get your measurement. then re-bounce if adjustments are necessary.
Devin Emke
Audio Post Production
Saturday Night Live, NBC
Old 02-17-2021, 01:20 PM
seanmccoy seanmccoy is offline
I use WLM constantly on the master Mix Bus, and not only does it calculate while offline bouncing, it shows the activity in real time while bouncing. So I'm confused as to why it's not working for you.
Custom i9-12900K, 64GB RAM, W10 Pro, PT Ultimate 2024.03, HD Native, OMNI, Digi 192, UAD-2 Octo; Mac Pro 12-core 3.46, 64GB RAM, Mojave, Logic Pro 10.5.1, Apogee Rosetta 800, UAD-2 Quad, MOTU 2408 Mk II: MBP mid-2012, 16GB RAM, Mojave, MOTU 8-Pre-ES, Pro Tools 2021.7
Old 02-17-2021, 11:00 PM
I think, Pro Tools should show the meterings while bouncing, independently which plugin is open. But it doesn´t. I mean, I´ve seen this before, but I don´t know where to turn that on.
Hardware:
24 GB RAM
System-Volume: SSD
Audio-Volume: SSD
Nuendo 11.0.0
Old 02-17-2021, 11:06 PM
Or maybe, it´s a generell issue in my settings. I see, that there are multiple problems:
- metering while bouncing
- handle length and "clip by clip" in audio suite don´t work any more
- keyboard setting is "german" in the main settings tab, but ProTools turns my keyboard to USA settings.
Can I trash the prefs anywhere so that ProTools is reset to factory default?
Hardware:
24 GB RAM
System-Volume: SSD
Audio-Volume: SSD
Nuendo 11.0.0
Old 02-18-2021, 12:22 AM
I trashed, but that din´t bring any solution
Hardware:
24 GB RAM
System-Volume: SSD
Audio-Volume: SSD
Nuendo 11.0.0
Old 02-23-2021, 06:57 PM
smurfyou smurfyou is offline
The newest version of WLM does not show the meter during offline bounce. Previous versions did. Not sure what changed.
~Will
Old 02-23-2021, 07:08 PM
devinemke's Avatar
the problem you are describing sounds a lot like the issue i raised in this thread. i have an open support case with Waves about this. i am only seeing this behavior on my macOS 10.14 machine. my macOS 10.15 does not have this issue. what OS/Waves version are you using?
thanks
Devin Emke
Inserts and bouncing offline Wawili_Sound Pro Tools 12 2 07-20-2017 12:47 AM
HDX Card and Offline Bouncing??? EdFaris Pro Tools HDX & HD Native Systems (Mac) 14 04-09-2013 01:25 PM
No offline bouncing ??? maxon Pro Tools 10 33 11-27-2012 09:20 AM
offline bouncing? production Pro Tools 9 1 11-07-2010 09:07 AM
Offline bouncing Logic with MC Mix torsig1967 Artist Series 2 11-03-2010 12:13 PM
