PT 8.0 + Reason issue + PT 8.0.1 update issue
macbook pro 2.16 (intel) / original MBox / PT 8.0 / OS 10.5.8
I find it easy to get confused with the compatibility grid @ times, but it looks like I'm not trying anything crazy.. I've been using 10.5.8 with my original MBox and PT 8.0 flawlessly for about 1/2 year now.. no issues whatsoever.. everything seems to work seamlessly.. 1) I have Reason 3.0.4.. it runs well stand-alone. When I try to open reason files with PT sessions that were previously created, I get the message "the plug in is inactive because it is not in the plug ins folder". Reason does not show up as an "instrument" plug in as it usually does as well. a) I do find the digirewire.dpm in Library>application support>Digidesign> plug ins b) I have tried opening reason and then opening my PT files.. I have tried opening reason, then closing it, then opening PT, then re-opening reason.. nada (most of what I have read has to do with the digirewire .dpm NOT being in that plug ins folder. 2) I thought I should go ahead and download the free PT 8.0.1 update, but I am getting a strange error message that seems to have something to do with java.. of course I'm not certain: "download error Java Plug-in 1.5.0_28 Using JRE version 1.5.0_28-b04-382-9M3326 Java HotSpot(TM) Client VM User home directory = /Users/cazuaga" I've not had an issue like this to date.. thanks in advance for any help.. |
Re: PT 8.0 + Reason issue + PT 8.0.1 update issue
I'm pretty sure Reason Adapted didn't get updated to Intel until 3.0.5.
Also, if you go to: Macintosh HD > Library > Application Support > Propellerhead Software > Rewire, do you have a require component for Reason here. After everything went intel Pro Tools would disregard all non universal binary plugins which is why i suspect you can't see it in inside Pro Tools. It's likely your running under Rosetta which was the piece of software that allowed PPC code to work with intel macs.
iMac i5 2.8GHz, Macbook Pro 2.4GHz, Pro Tools 10/11, MOTU 828mk2, Presonus Digimax FS, Presonus Firestudio Project, TC Konnekt 24D --- iCON Photography |
10.3 Update - Windows shutdown issue has returned. Update at your own risk. | crm0510 | Windows | 14 | 09-19-2012 01:50 PM |
PT 8 and Reason 3 Issue | VanDerGraf | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 01-16-2009 03:06 PM |
PT 7.4 w/ Reason 4 Issue! | Say-Wut | Pro Tools M-Powered (Win) | 1 | 04-03-2008 04:15 PM |
Issue with Reason | Stixntrixx | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 07-28-2006 10:38 AM |
Reason Dr. Rex issue | LeGato | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 12-14-2004 03:12 PM |
