Old 02-14-2006, 06:16 PM
Dr Dave Dr Dave is offline
Default AMDX2 Jerky meter and counter behaviour solved!
Hi all,
After upgrading to a very fast and efficient dual core PC (not to mention expensive!), I was pretty disappointed to find that Pro Tools was not performing as it should. The meters and counter displays were jerky and out of sync with the music being played. I also suspected that the MIDI behaviour was also suffering because I noticed that some of my MIDI'd outboard gear was not running as smoothly as it had before. However Microsoft have released a hotfix for this problem and it applies to Windows XP SP2. The hotfix is relevant to nearly all AMD64 X2 dual core processors. I installed the hotfix (and completed the necessary regedits) and now everything runs very smoothly. Problem fixed. I thought I'd let others on the Forum know of this fix. I found it here:
http://www.amdzone.com/modules.php?o...ticle&sid=3964
I am running a PC with the following relevant components:
AMD64 X2 4800+ dual core
Asus A8N-SLI motherboard
2 x SATA Raptor 10,000 rpm drives
1 GB of Corsair DDR RAM
Leadtek GeForce 6800GS video card
Delta 1010 Audiocard
Now...time to get recording and mixing!
Regards,
Dave
Old 02-15-2006, 07:31 AM
alexkbd alexkbd is offline
Default Re: AMDX2 Jerky meter and counter behaviour solved!
Dr Dave you have made my day!!
Finally - working midi and nice smooth meters...
Great detective work!!
Old 02-16-2006, 07:32 PM
vtmaestro vtmaestro is offline
Yes this fix and regedit worked for me too!!!!! I love my new Athlon x2 System!!!!
Athlon 64 x2 3800
ASRock 939 Dual-Sata Mobo
2 Gig DDR 400 Ram
Digi 002
Old 02-19-2006, 04:37 PM
Thanks for the feedback and I'm glad to have helped by pointing some people in the right direction. It makes a HUGE difference to the AMDx2 machines when running Pro Tools. Let others know!
Inserts affecting send meter but not channel meter? Kbrinson85 Windows 1 05-01-2012 07:00 AM
Main counter mode not switching using "counter" switch bashville ICON & C|24 2 08-07-2009 04:07 PM
Strange DAE and EA Behaviour(Solved) Kris75 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 12-01-2007 05:58 PM
SOLVED>>Need HELP, SUPER ASAP.< audioindo Pro Tools TDM Systems (Mac) 18 04-21-2007 05:43 AM
HELP! Jerky Meters, Counter, and Scrolling evanbrubaker Pro Tools TDM Systems (Mac) 7 08-10-2001 03:51 PM
