M-Powered 7.0 + FW1814 MTC timeout?
Hi All - would appreciate any thoughts regarding the following:
Upon setting up the click plugin on an aux track and starting the transport - a few "clicks" are audible as expected and then silence (input signal on the plugin also stops illuminating) though transport remains playing. Number of clicks seem to be fairly random - sometimes one single click, sometimes up to two bars will sound... any instruments also behave in the same way - a short burst of sound followed by silence. Am using latest 1814 drivers (5.10.0.5036) and have tried CS1 update. System is: Asus A8N-E AMD 4400+ X2 2GHz Ram Love to hear from you!! |
Re: M-Powered 7.0 + FW1814 MTC timeout?
I have the same setup as you.....
AMD X2 XP4400+ with an M-audio Firewire 1814. Noticed for the first time last night an odd thing when I recorded a couple of bars of midi data and then went to loop the data. It played back the first 2 bars but when it got to the first looped section it played a short burst and then no sound until the next copy of the loop came around in bar 5 then another short burst and nothing etc. I wonder if this is related? |
Hey!
Seems a little odd doesn't it? Do you have A8N-E too? Found this post with a similar issue with PTLE and 4800+ X2 - have a read: http://duc.digidesign.com/showflat.p...fpart=1#934619 Alex |
I have an A8N-SLI-Premium....not that much different..same manufacturer.
A timeout occurred | Wisur | Pro Tools TDM Systems (Win) | 10 | 11-17-2012 08:04 AM |
Win XP Sp3 + M-Powered 7.4 + FW1814 = What drivers? | Finnish | Pro Tools M-Powered (Win) | 1 | 02-22-2011 07:30 AM |
Direct Monitoring in FW1814 and ProTools M Powered | LesPaul666 | Pro Tools M-Powered (Mac) | 3 | 05-06-2006 09:45 PM |
FW1814 doesn't work with M-Powered! | Aleatoric | Pro Tools M-Powered (Mac) | 5 | 05-13-2005 07:29 AM |
Getting Timeout while recording. | WoodMan | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 05-31-2002 07:47 AM |
