Old 11-13-2018, 05:08 PM
Default Re: HELP! I just got PT, but I get an error whenever I try to start it!
In future it would help if you actually read the “help us help you” link and follow the instructions to post the proper Sandra report. Like the thousands of others posted on DUC that you can look at to see.
But on interfaces.... so you have a crappy audio interface, do you also have a “proper” audio interface with native ASIO driver? Are you planning on recording audio? who knows if you have ASIO4ALL configured properly or not or wether you could be using the WASAPI driver. ... you could be doing things like posting screenshots of the playback engine dialing (and listing all choices in the pull down)!and ASIO driver configuration page etc. but right now I cannot even tell where you are at with the problem and it’s taken this long to get a fraction of a normal Sandra report...
Old 11-20-2018, 10:04 PM
AndrewAction's Avatar
AndrewAction AndrewAction is offline
Originally Posted by IB98 View Post
I just bought the 9.99 per month Pro Tools Subscription, downloaded it (Pro Tools 2018.10 Win), but could NOT open it because of an error I got:
FWIW the following works for me. uninstall ASIO4ALL then see if Pro Tools starts.
If it startup properly quit Pro Tools and reinstall ASIO4ALL
Reboot your Computer (important)
Open Pro Tools holding the N key.
In settings open the Playback option and select ASIO4ALL. Set the hardware buffer size.
If this works then you should be able to open Pro Tools normally. In my case all subsequent Pro Tools and MC update installs broke Pro Tools startup again.
Andrew
Old 11-21-2018, 12:55 AM
tamtamstudio tamtamstudio is offline
SAME ERROR THIS MORNING HERE!
Impossible to work.
Corrado Magalotti
Tam Tam Recording studio
Old 11-21-2018, 12:59 AM
Impossible to work.
So? What do you want anybody here to do?
The thread you are posting to has some information on how to address these issues. If you want actual help from folks you need to take the time and explain your system and what interface you are trying to use and what troubleshooting you have done.
Old 11-21-2018, 01:42 AM
Hi all, problem solved.
seems a new kid on the block, today.
Anyway, starting with N key to see what's changed on audio configuration.
I switched from ProTools Aggregate to Pre-Sonus driver and it worked again.
I didn't know what's up. Yesterday evening I was the latest to use and I'm the first this morning on that machine.
The other DAW (HDX) is fine.
both on mac
Corrado Magalotti
  #16
Old 11-21-2018, 02:57 AM
You can delete the aggreagate device (if you never use it) in audio MIDI setup to reduce this happening in future.
  #17
Old 11-21-2018, 03:13 AM
Yes, I’ll do ASAP!
Never used, since when it was available long time ago!
Btw, why it was switched and who did it?
Thank u.
Inviato dal mio iPhone utilizzando Tapatalk
Corrado Magalotti
  #18
Old 11-21-2018, 04:05 AM
standard behavior of Pro Tools.... you have to check/start with N to be sure.
Error During Start Up DirtyPopsicleProd Pro Tools Express on Windows 0 03-05-2013 12:00 PM
Error: 3 on Start Up orage macOS 0 09-17-2012 11:16 AM
ERROR - 192 AT START UP dizzove Tips & Tricks 1 10-31-2007 11:58 AM
7.3 error pop-up @ start up ostrange 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 01-04-2007 04:00 PM
LE Start up error harrison_pooley 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 10-05-2005 06:23 AM
