Old 11-12-2018, 02:44 PM
andresdotcom andresdotcom is offline
Default ProTools and FocusRite 2i2
I'm having problems getting my interface to speak to ProTools. I've attempted to delete and set Default on the I/O to no fix. I am getting signal on my interface, but none going to the DAW.
I have ProTools 2018.3, FocusRite 2i2 interface, and MacBook Pro OC Mojave 10.14.1.
I know can work because I recorded on it before. Now, for one reason or another, it doesn't work. Lastly, to remove any doubt, yes, I have tried to enable track to view signal in the DAW to no win.
Can anyone help?
Old 11-12-2018, 04:34 PM
crizdee's Avatar
crizdee crizdee is offline
Default Re: ProTools and FocusRite 2i2
Can anyone help?
This system has worked before on Mojave? Mojave is not qualified for this version of PT
details here...
http://duc.avid.com/showthread.php?t=401210
Chris
Producer, Engineer,
www.ukmastering.com
Old 11-12-2018, 05:07 PM
AlexLakis AlexLakis is offline
Serendipitously, I have just tested the Focusrite Scarlett 2i2 on Mojave 10.14.1 and it works just fine! I am running Pro Tools 12.6. The interface functions perfectly in Pro Tools, Logic, and iTunes/system.
Have you tried using Aggregate I/O instead of the actual interface in Pro Tools? That used to work for me on 10.8.5. Make sure you reset ALL I/O settings including bus settings, not just Input/Output. You could try resetting preferences (I think there's a sticky for it here on the DUC). After that, maybe uninstall and do a clean install of Pro Tools.
That's all I can think of right now!
Old 11-12-2018, 06:08 PM
You need to enable microphone permission in macOS security and privacy preferences. This has been discussed on DUC already (so a search should have found it). I hope Avid has future supported versions of Pro Tools pop up a warning about this-should be easy to do.
Old 11-13-2018, 12:16 PM
Chris, hi. That might be what it is. Mojave not qualified for this version of PT. When I used ProTools on this laptop, I had the previous OS. Now that it's upgraded to a new OS, I cannot work with PT.
AlexLakis, interesting. Very well. I will look into your "input." Thank you, sir.
Darryl Ramm, very interesting!! I will look into this as well. Seems like that will fix the issue. Thank you as well.
Old 11-13-2018, 12:25 PM
Darryl Ramm, YOU'S THE MAN!! Thank you! Enabling microphone permissions on macOS sercuity and privacy preferences fixed the dilemma. You're a huge help. Thanks!!
Thank you all who reached out to try and help!!
Protools 10 and Focusrite Scarlett 6i6 DHeavy Third Party Interfaces 2 12-26-2017 09:54 AM
ProTools 11 and Focusrite jdcable Pro Tools 11 6 03-20-2015 02:48 PM
Using Focusrite Saffire Pro 24 with Protools 10.3.5 aussie45 macOS 6 06-25-2013 05:42 PM
Focusrite Liquid Mix and ProTools 9 playground_strifer Pro Tools 9 1 03-25-2011 03:20 AM
Protools and Focusrite ISA 430 a/d card Hanslemonverm 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 05-10-2005 08:57 AM
