Help! Those using HDX,old MacPro,RX580
My 7950 took a dump in my 5,1. I bought an RX580 since I read a Bunch of folks had success with a 5,1. I
was already using a motherboard power adapter to use HDX. Now I admit I am totally lost. If this $$!! Card needs 2 power slots, where will I get HDX power? Already canceling sessions. Can anyone offer how they’ve done it with that configuration? Or is it impossible?
Brian www.brianjanthony.com MacPro 6 core 3.46 Cheese Grater HDX and HD NATIVE 48 gig Ram PT 2019. Something Sierra 192 IO and 96 IO TDM user way back. PT user since 98. I'm either working, sick, or both. Last edited by brianjanthony; 02-17-2020 at 12:53 PM. |
Re: Help! Those using HDX,old MacPro,RX580
I just upgraded the same setup minus the HDX, I use HD Native. However, I found a few sites explaining hooking up an external PSU.
Extra Aux Power Another guide
-Ryan Young •2019 Mac Pro 3.5 GHz 8-Core Intel Xeon W - 48 GB 2666 MHz DDR4 (OS 10.15.5) •HD Native PCIe, HD Omni, 192 I/o, Pro Tools Ultimate •Avid S3 + Dock •Blackmagic Intensity Pro (HDMI) •5.1 Room with JBL LSR4300 series
You take the power from the optical drive area. Pull the cage up there and tap into the SATA power to run the HDX cards (takes a little work to weave the power cable down to the main slot area but it is doable.)
Also takes adapter cables (few dollars) you can find on Amazon to tap into the SATA power (more than enough there for 3 HDX cards.) Unfortunately mine is all racked away or I'd open it up and take some pictures. I also don't remember which adapter cable you need but I'm sure someone on the web has posted step-by-step instructions or a buy list. (I do remember you need to use the PC power cable that come with the HDX cards instead of the Mac one -- along with the adapter)
Pro Tools Ult 2024.3, HDX 2, MTRX/SPQ, RME BBF Pro + MADIface Pro • S1 x 2, Fire HD10 + Max11, Dock, iPad Air5 • Mac Mini 14,12, 12 core, macOS 13.6.5 • RAM 32GB, SSD 4TB, GPU 19 core • QNAP TVS-872XT 148TB TB3 |
When you get it working you’ll thank your old GPU for dying. Pro Tools is much happier on a 580.
Which OS are you running? Let us know how you get on.
James Welch Recording Engineer | Producer Masterlink Productions Mac Mini 8,1 (2018) | 3.2 GHz 6-Core Intel i7 | 64GB Ram | Apple 27" LED Cinema | 2TB System Drive | LaCie Rugged USB-C 2TB SSD NVMe Audio Drive | UAD-2 Quad Satellite (Firewire) macOS Catalina 10.15.7 | Pro Tools Ultimate 2021.7 | Avid HDX TB3 Chassis | HDX | Avid Omni | Avid 16x16 HD I/O x2 | Digidesign 192 | Digidesign C24 |
I’m getting on terribly lol. I’ve got a 580. For the hell of it bought an external
Power supply. Plugged in card to Mac. Tested power supply (it’s working 600w). Plugged supply into wall. Plugged 8 pin into graphics card. Fans didn’t spin. Nothing works. I’m a longtime Mac user (since 93). I’ve never done this and live way too Close to a river. I wanna throw everything in said river. I’d be happy if the 580 fans would spin when connected to power supply. No dice. Even crappier, I managed to buy the one damn supply where you need it to jump Wires on some 24 Pin connector just to make IT work. I’m sure I’m missing something. Tearing my hair out.
Brian www.brianjanthony.com MacPro 6 core 3.46 Cheese Grater HDX and HD NATIVE 48 gig Ram PT 2019. Something Sierra 192 IO and 96 IO TDM user way back. PT user since 98. I'm either working, sick, or both. |
See if this helps you Brian:
http://blog.greggant.com/posts/2018/...uide.html#pcie Scroll through it.
Marti D. Humphrey CAS aka dr.sound www.thedubstage.com IMDB http://www.imdb.com/name/nm0401937/ Like everything in life, there are no guarantees just opportunities. |
I think maybe I’ve got it going. Just now remembering that this isn’t a flashed card, I waited a while when I booted. After a few minutes, screens started up. Now I 1) have to thread cables thru pci slots in back and 2)figure out a way to
Permanently jump the pins on that power supply.
RX580 + HDX on a Cheesgrater Macpro5.1 | Stephen Webster | Pro Tools HDX & HD Native Systems (Mac) | 6 | 03-28-2020 04:42 PM |
