Old 02-01-2020, 12:54 PM
garnoil garnoil is offline
Default Automation too dense???
it is 2020, I am running an HDX 1 on a Mac Pro 5,1 using 189 voices of the possible 256 and I am getting "automation too dense errors"...I have 96 gigs of RAM and my cash is at 12 gigs...may be back in 1995 but with todays computers? I have t set up to 'trim some automation' and still...may be it is wring error and just needs a re-boot.
Old 02-01-2020, 03:01 PM
Default Re: Automation too dense???
Reboot is probably my first step for that. Trashing prefs would be #2
Old 02-01-2020, 09:30 PM
smurfyou smurfyou is offline
There were a handful of people in the Post forum with these errors. I think it was certain plugins that were suspected but no certain solution. I'd report it to Avid, the more bug reports the better.
~Will
Old 02-02-2020, 01:04 PM
Ryan Young's Avatar
Ryan Young Ryan Young is offline
At work, we get this error all the time. Every single track is set to automation off, the automation window is on suspend, there is zero automation in the session. But frequently, when hitting play or record... "Automation too dense".
-Ryan Young
•2019 Mac Pro 3.5 GHz 8-Core Intel Xeon W - 48 GB 2666 MHz DDR4 (OS 10.15.5) •HD Native PCIe, HD Omni, 192 I/o, Pro Tools Ultimate •Avid S3 + Dock •Blackmagic Intensity Pro (HDMI) •5.1 Room with JBL LSR4300 series
Additional Systems
•2010 Mac Pro 2 x 2.66 GHz 6-Core Intel Xeon - 48 GB 1333 MHz DDR3 (OS 10.14.6) •HD Native PCIe, 192 I/o, 96 I/o, Pro Tools Ultimate •McMix (x4), McControl (x1), JLCooper Surround panner for D-Command ES, Avid Control •Blackmagic Intensity Pro (HDMI) •7.1.4 Room with JBL LSR4300 series
•2017 MacBook Pro 2.8 GHz i7 - 16 GB 2133 MHz LPDDR3 (OS 10.14.6) •HD Native TB, HD Omni, Pro Tools Ultimate •McMix (x1), McControl (x1), Avid Control * or * D-Command ES Main Unit •Fed into whichever system is the main system
Old 02-03-2020, 07:50 AM
dr sound's Avatar
dr sound dr sound is offline
There are a few tips I can give you:
Set your cache to "normal"
It seems that if you have a template from all your mixes
that you created on versions of PT years ago and have
continued to update it over the years there are some legacy
issues that appear when you do big sessions.
It has happened to me on HUGE sessions both in 5.1 and
Dolby Atmos. I also found that if I suspend automation to
write an update and then hit play and then take suspend out
after hitting play it also causes "automation too dense" errors.
I created a brand new template from scratch recently and have
worked on big sessions in Dolby Atmos and have not once again
had that error with my new template and my awareness not
to hit play and then take suspend out.
Both of these approaches have given me flawless sessions.
Marti D. Humphrey CAS
aka dr.sound
www.thedubstage.com
IMDB http://www.imdb.com/name/nm0401937/
Like everything in life, there are no guarantees just opportunities.
Old 06-11-2020, 11:24 PM
fsavell fsavell is offline
This appears to be accurate. I have a case open with support and they indicated that its possibly correlated with the sessions coming from old versions of PT. I've had no issues on newly created sessions, but these few particular big sessions that have migrated through v9/10/11/12>v2020 have some kind of "virus" attached to them. If I import anything (plugin settings/routing etc) from these corrupted sessions, it infects the newly created session. I get the Automation too Dense message, I get sessions that load with random inactive plugins (when they were saved active) and bounce/commit crashes that can't be attributed to any particular plugin (it seems more related to the number of plugins loaded in the session). It's frustrating. I've found restarts or moving all the 3rd party plugins into unused plugins and back again, solves it, for a while, but best to avoid using old migrated sessions, if possible.
Forrester
Pro Tools Ultimate 2023.12, HDX1 • Mac Studio M2 Ultra - macOS 14.2
Old 10-23-2020, 06:26 PM
mrtomcat mrtomcat is offline
I just got a 2019 Mac Pro 12core 48 gig ram Radeon Pro W5700X, HDX Card
I was on a 2018 Mac mini before with the HDX running in a Sonnet chassis...
I was always at a buffer of 256 which works perfectly fine even during recording there is no noticeable latency... only when I am mixing where I am using several Artist mixes, there's always latency with the faders when creating automation.
I was hoping on the new Mac Pro I can lower the buffers to avoid that...
When tracking I can now easily go to 64 buffer size and the machine doesn't even blink... awesome! But when I open a full mix session (about 100 tracks) and I lower the buffer to 128 I start getting the Automation too dense error (even after I thin out the automation... I am actually not sure what that even does...) the moment I go back to 256 everything runs fine. Based on this thread it might be very well the older session (not even a year old though)...
The CPU barely coughs and the HDX looks like it should still be able to handle more... But I am wondering if that is related to the HDX card and I'd need a second one (not preferred) Has anyone figured out what the actual cause is, since this thread is several months old?
I appreciate your help
PT Ultimate 2021.10
Nuendo 10.3
Wavelab Pro 11
UAD Satellite Octo Thunderbolt, UAD Quad Pcie
Apollo Twin Duo,
HDX Card,
2x Avid I/O Analog 16/16,
4x Artist Mix, Avid Dock, PT Control,
2019 Mac Pro 12 core, 48 gig Ram, running Big Sur,
lots of outboard gear
Automation is too dense (-9155) HDXSound Pro Tools HDX & HD Native Systems (Mac) 9 09-27-2013 01:02 AM
AUTOMATION TO DENSE then stops..... I have no automation Weird Audio Pro Tools TDM Systems (Mac) 1 12-07-2012 05:50 AM
Automation too dense ? deardaddy Pro Tools TDM Systems (Mac) 4 08-26-2006 11:23 AM
automation is too dense? c-post Pro Tools TDM Systems (Mac) 6 07-03-2006 07:07 PM
Automation too dense during BTD roykamen Pro Tools TDM Systems (Mac) 6 12-12-2000 10:44 PM
