Cant play 24 track in 24bit mode
When i try too play 24 tracks in 24 bit mode the system stops and the message "dae could not complete this request disk may be too slow...etc" . The problem occures on both internal and external scsi disk which is very fast . The problem do not occure in 16 bit mode .I hav 0.1 % fragmented files on both disks and no corrupted files . I have tryed to increase dae buffer size on different levels and increasing dae memory . Nothing helps !! . In 24 bit mode the digi 001 only play back 18 tracks and nothing more .
My system is G4 350mhz , 320mb ram ,seagate barracuda 17 gb scsi disk . Do anyone have the same problem .What is the best setting for my computer ?? Thanks for all help !!! |
Re: Cant play 24 track in 24bit mode
-What SCSI card are you using?
-What format utility did you use to initialize your audiodrive(s)? -What version of Pro Tools are you running? Brent |
Thanks for answering !
I use a adaptec 2930 scisi kort and have init my harddisks with FWB tool kit and i run verson protools 5.01 |
-Adaptec 2930 SCSI cards are not supported with G4 computers. For a list of supported devices, please go to:
http://www.digidesign.com/compato/001g4pci.html -FWB HDT is no longer supported with Pro Tools. Backup and reinitialize your SCSI drive(s) with ATTO ExpressPro-Tools v2.3.2. This software is located on your PT LE 5.0.1 CD-ROM. All ATA drives should be initialized with Apple Drive Setup. Brent |
play a 24bit session on a 882/20 | DavidHeylen | Pro Tools TDM Systems (Mac) | 2 | 01-13-2008 06:50 AM |
"Play Pause" mode? | bfoster | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 03-29-2007 02:09 PM |
Can't Change Automation Mode while in Play Mode | menotyou | ProControl, Control|24, Command|8 | 6 | 09-16-2004 06:29 AM |
can't hear audio with track in play mode | slim chrispy | Tips & Tricks | 2 | 06-08-2004 07:06 AM |
HELP - More -9093 errors in 24bit Mode. | digi2000 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 09-27-2001 12:54 AM |
