HD Cards explanation.
Can someone explain to me what is the difference between these cards: HD Accel, HD Core Accel etc.? Is there a card only for TDM plugins, like UAD, which I can use with my DGI 003 simultaneously? Thank you in advance!
MacPro 2.66GHz 8Gb RAM Mac OS X 10.7.5, Pro Tools 10.3.3, DIGI 003 Factory, LogicPro 9.1.8, Tascam FW-1884, Adam A7, Roland TD-20, Yamaha SY-99, Audiotechnica ATH-M50. |
Re: HD Cards explanation.
HD core is needed to run PT HD then u can add up to 6 Accel cards to increase your TDM power. There are the old PCI-X cards and the newer PCIe cards. I looked into this quite a lot before buying my system and according to the Avid white papers when you get a HD3 PCI-X one core and 2 accel cards there is no performance different between this and PCIe. I've not used UAD so I'm not to sure but I think their plugs run of their cards saving your PC's power. I would think that u could use this with your 003 but I'd check with UA first. If you are thinking of buying HD cards you will need an interface and some preamps unlike or 003 as its an interface and preamps in one.
Hope this has helped
Raoul Crane
www.blaze-studios.co.uk PT 10.3.10 HD Accel 6, Mac Pro 5.1 12 Core 3.46hz Dual Boot Lion 10.7.5 and Maverick 10.9.5 32GB Ram Magma PE6R4i Chassis |
Thanks, Raoul! I am curious if I can use one of these cards only to load on it TDM plugins. I don't need additional I/O.
You won't be able to use the PT cards with your current set up I'm not sure about UAD best check with them
Raoul Crane
Got it, thanks! As for UAD I can use them along with my DIGI 003.
No probs glad I could help
Raoul Crane
The only way to run TDM plugins is with a system that has a bare minimum of:
Your digi 003 will not work in any configuration that can run TDM plugins. That being said, if you have a computer with PCI or PCIx slots, the older PCI HD core cards can be bought second hand for around $500 or so these days... so the cost difference between your 003 and HD is not as drastic as it used to be. EDIT: just saw you have a mac pro in your sig, so you would need the PCIe core card, which sells for around $1500-2000... So you would still need a few thousand to do the upgrade.
- John If a MIDI event triggers a sample of a tree falling and there's no one there to hear it, does it make a sound? |
I'll skip the upgrade. :)
I didn't and I've never looked back
Raoul Crane
Agreed, but I cannot afford HD system without selling my gear.
DSP explanation | strangedaysuk | Pro Tools TDM Systems (Mac) | 5 | 08-03-2011 09:03 AM |
DTS...need iLok explanation...pls | mykhal c | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 12-21-2009 03:59 PM |
Explanation of AFL/PFL and examples when to use | PTGuy | Pro Tools TDM Systems (Mac) | 15 | 01-08-2007 06:56 PM |
DC Offeset Explanation | Eric G | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 05-19-2005 11:58 AM |
Glyph Explanation | distressor | Pro Tools TDM Systems (Mac) | 7 | 10-12-2003 08:58 AM |
