Old 01-04-2010, 12:37 PM
ccgascity1 ccgascity1 is offline
Default 003 rack is not connecting. Blinking green light. no HOST 1394 light.
When I fire up Pro Tools, I get a message that says "Unable to locate digidesign hardware". I have tried everything I can think of to solve this problem. I have even reinstalled my mac to factory settings and updated everything again. When I turn on my computer, the Link light on the back of the rack lights up and blinks. The HOST light in the front does not light up at all. Any suggestions? Thanks
Old 01-04-2010, 07:39 PM
basslik's Avatar
basslik basslik is online now
Default Re: 003 rack is not connecting. Blinking green light. no HOST 1394 light.
I just had the same error, I had to jiggle my firewire cable around, (powered off first), hope that does the trick?
MAC PRO 2010 5,1 3.46hex 128ram - HIGH SIERRA - PT 2020.3 / 003 CONSOLE /DIGIMAX FS /PCM90 2CHANNEL SPDIF
Old 01-04-2010, 08:50 PM
nst7 nst7 is offline
If you're using the firewire cable that came with the unit, that could be the problem. It stinks. You can get a better one. I personally use a Monster firewire 6 pin to 6 pin. Sam Ash usually carries them. You might also find a decent quality one at Best Buy or something.
Old 05-23-2010, 07:36 AM
rcalderonm rcalderonm is offline
Hey im having the same problem, im running pro tools 7.4 on a macbook pro 10.6.3 (snow leopard), one day i was starting protools and this message appeared in my screen "Unable to locate digidesign hardware". i went to the local music store, one guy advice me to update the firmware of the 003 and try to get the last version of protools, the 8.0.3.
apparently nothing happens, the link indicator on the back of the 003 rack blinks, and HOST 1394 light indicator on the front panel is off.
i really need help!!!!!
Old 05-24-2010, 11:22 AM
DigiTechSupt's Avatar
Did you get 8.0.3? If not, that's likely the problem, as 7.4 is not compatible with Snow Leopard and you need compatible drivers installed for the 003 to work properly.
Avid Audio Tech Support
Support FAQ
Old 01-14-2011, 02:35 AM
bkncalibur bkncalibur is offline
I just installed 8.0.3 right now with my 003 rack and just got the same green light blinking issue and pro tools freezes. im running windows vista ultimate 32bit. any check i can do? should i downgrade to 8.0.2?
Old 01-14-2011, 12:41 PM
Park Seward's Avatar
Park Seward Park Seward is offline
This is the Mac forum. You may get better answers in the Windows forum. I can't help with Windows problems. Sorry.
Park
The Transfer Lab at Video Park
Analog tape to Pro Tools transfers, 1/4"-2"
http://www.videopark.com
MacPro 6 core 3.33 GHz, OS 10.12.1, 8 GB RAM, PT12.6.1, Focusrite Saffire Pro 40, PreSonus DigiMax, MC Control V3.5, dual displays,
Neumann U-47, Tab V76 mic pre, RCA 44BX and 77DX, MacBook Pro 9,1, 2.3 Mhz, i7, CBS Labs Audimax and Volumax.
Ampex 440B half-track and four-track, 351 tube full-track mono, MM-1100 16-track.
003 rack blinking green light?? gabrieljay 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 04-29-2010 11:31 AM
003 rack Host light blinking - HELP! rockwell81 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 01-20-2010 07:53 PM
003 Rack - Internal green light blinking suitelounge 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 11-30-2008 12:58 AM
1394 Light on Digi002 Rack keeps blinking doviedo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 03-15-2008 09:06 AM
1394 light blinking on and off on my rack?!? help! chal7ds 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 07-12-2006 10:31 AM
