Old 02-17-2020, 12:26 PM
brianjanthony's Avatar
brianjanthony brianjanthony is offline
Default Help! Those using HDX,old MacPro,RX580
My 7950 took a dump in my 5,1. I bought an RX580 since I read a Bunch of folks had success with a 5,1. I
was already using a motherboard power adapter to use HDX. Now I admit I am totally lost. If this $$!! Card needs 2 power slots, where will I get HDX power? Already canceling sessions. Can anyone offer how they’ve done it with that configuration? Or is it impossible?
Brian
www.brianjanthony.com
MacPro 6 core 3.46 Cheese Grater
HDX and HD NATIVE
48 gig Ram
PT 2019. Something
Sierra
192 IO and 96 IO
TDM user way back. PT user since 98.
I'm either working, sick, or both.
Old 02-17-2020, 12:54 PM
Ryan Young's Avatar
Ryan Young Ryan Young is offline
Default Re: Help! Those using HDX,old MacPro,RX580
I just upgraded the same setup minus the HDX, I use HD Native. However, I found a few sites explaining hooking up an external PSU.
Extra Aux Power
Another guide
-Ryan Young
•2019 Mac Pro 3.5 GHz 8-Core Intel Xeon W - 48 GB 2666 MHz DDR4 (OS 10.15.5) •HD Native PCIe, HD Omni, 192 I/o, Pro Tools Ultimate •Avid S3 + Dock •Blackmagic Intensity Pro (HDMI) •5.1 Room with JBL LSR4300 series
Additional Systems
•2010 Mac Pro 2 x 2.66 GHz 6-Core Intel Xeon - 48 GB 1333 MHz DDR3 (OS 10.14.6) •HD Native PCIe, 192 I/o, 96 I/o, Pro Tools Ultimate •McMix (x4), McControl (x1), JLCooper Surround panner for D-Command ES, Avid Control •Blackmagic Intensity Pro (HDMI) •7.1.4 Room with JBL LSR4300 series
•2017 MacBook Pro 2.8 GHz i7 - 16 GB 2133 MHz LPDDR3 (OS 10.14.6) •HD Native TB, HD Omni, Pro Tools Ultimate •McMix (x1), McControl (x1), Avid Control * or * D-Command ES Main Unit •Fed into whichever system is the main system
Old 02-17-2020, 01:24 PM
BScout BScout is offline
You take the power from the optical drive area. Pull the cage up there and tap into the SATA power to run the HDX cards (takes a little work to weave the power cable down to the main slot area but it is doable.)
Also takes adapter cables (few dollars) you can find on Amazon to tap into the SATA power (more than enough there for 3 HDX cards.) Unfortunately mine is all racked away or I'd open it up and take some pictures.
I also don't remember which adapter cable you need but I'm sure someone on the web has posted step-by-step instructions or a buy list. (I do remember you need to use the PC power cable that come with the HDX cards instead of the Mac one -- along with the adapter)
Pro Tools Ult 2024.3, HDX 2, MTRX/SPQ, RME BBF Pro + MADIface ProS1 x 2, Fire HD10 + Max11, Dock, iPad Air5 Mac Mini 14,12, 12 core, macOS 13.6.5RAM 32GB, SSD 4TB, GPU 19 coreQNAP TVS-872XT 148TB TB3
Old 02-18-2020, 12:17 PM
the.engineer the.engineer is offline
When you get it working you’ll thank your old GPU for dying. Pro Tools is much happier on a 580.
Which OS are you running?
Let us know how you get on.
James Welch
Recording Engineer | Producer
Masterlink Productions
Mac Mini 8,1 (2018) | 3.2 GHz 6-Core Intel i7 | 64GB Ram | Apple 27" LED Cinema | 2TB System Drive | LaCie Rugged USB-C 2TB SSD NVMe Audio Drive | UAD-2 Quad Satellite (Firewire)
macOS Catalina 10.15.7 | Pro Tools Ultimate 2021.7 | Avid HDX TB3 Chassis | HDX | Avid Omni | Avid 16x16 HD I/O x2 | Digidesign 192 | Digidesign C24
Old 02-18-2020, 01:16 PM
I’m getting on terribly lol. I’ve got a 580. For the hell of it bought an external
Power supply. Plugged in card to Mac. Tested power supply (it’s working 600w). Plugged supply into wall. Plugged 8 pin into graphics card. Fans didn’t spin. Nothing works. I’m a longtime Mac user (since 93). I’ve never done this and live way too Close to a river. I wanna throw everything in said river. I’d be happy if the 580 fans would spin when connected to power supply. No dice.
Even crappier, I managed to buy the one damn supply where you need it to jump
Wires on some 24 Pin connector just to make IT work.
I’m sure I’m missing something. Tearing my hair out.
Brian
HDX and HD NATIVE
48 gig Ram
PT 2019. Something
Sierra
192 IO and 96 IO
Old 02-18-2020, 01:23 PM
dr sound's Avatar
dr sound dr sound is offline
See if this helps you Brian:
http://blog.greggant.com/posts/2018/...uide.html#pcie
Scroll through it.
Marti D. Humphrey CAS
aka dr.sound
www.thedubstage.com
IMDB http://www.imdb.com/name/nm0401937/
Like everything in life, there are no guarantees just opportunities.
Old 02-18-2020, 02:24 PM
I think maybe I’ve got it going. Just now remembering that this isn’t a flashed card, I waited a while when I booted. After a few minutes, screens started up. Now I 1) have to thread cables thru pci slots in back and 2)figure out a way to
Permanently jump the pins on that power supply.
Brian
HDX and HD NATIVE
48 gig Ram
PT 2019. Something
Sierra
192 IO and 96 IO
RX580 + HDX on a Cheesgrater Macpro5.1 Stephen Webster Pro Tools HDX & HD Native Systems (Mac) 6 03-28-2020 04:42 PM
