Elastic...adding Warp markers
Anyone know if there is a way to select a section of audio and place warp markers over all of the event markers? It only seems possible to add each one individually.
Thanks, |
Re: Elastic...adding Warp markers
Open the quantize window, set the sensitivity to 1 and quantize. You will then have all of the warp markers but they will not have moved any audio because of the low sensitivity setting. |
Thanks Vaporhead, I can't wait to try it.
macmandigital.com |
This may be obvious, but just in case I'll mention it...you won't see the sensitivity adjustment parameter in the quantize window until you select a groove template. It took me a while to figure that out. But then again, I can't find anything in the fridge either...
FYI, a fix in PT 7.4cs2 (and subsequent releases like cs3) may be relevant to your workflow:
Fixed: Elastic Time Warp Markers Could Move After Quantizing (Item #100423) * Quantizing a selected area could cause markers outside that selection to move http://www.digidesign.com/index.cfm?...4&itemid=29792 Jim West Digi |
Elastic Audio: Create Warp Markers From Analysis | Gatekeeper | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 02-07-2018 07:45 AM |
Elastic Audio and Warp Markers removal | stevegalante | Pro Tools TDM Systems (Mac) | 1 | 09-15-2011 01:54 AM |
How to turn all Event Markers into Warp Markers ??? | fman | Pro Tools TDM Systems (Mac) | 15 | 04-29-2011 01:46 PM |
All Event markers to warp markers? | audioluche | Pro Tools TDM Systems (Mac) | 9 | 01-11-2010 06:02 AM |
Copying and Pasting Warp Markers with Elastic Audio | dgraham500 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 08-21-2008 12:26 PM |
