Old 10-06-2013, 04:49 AM
FabriceMg FabriceMg is offline
Default Mbox2 PT11 and virtual instruments
I got PT11 and tried to use my mbox2 as I did before with PT LE.
I have updated my Mbox2 drivers and everything is working well except for instrument track :
If I create an instrument track, the virtual instrument doesnt react when I play my midi keybord (I can only play the instrument with the mouse !)
Can anyone help me please ?
I am using PT11 with Mbox2, on windows 8.
Thanks
Old 10-08-2013, 12:14 PM
cwsand's Avatar
cwsand cwsand is online now
Default Re: Mbox2 PT11 and virtual instruments
Thanks
Is the Mbox showing up under MIDI Devices? Did you check MIDI Thru under the Options drop down menu? Also, Check that you have the correct MIDI in/out channels enabled by using Instrument View in the Mix Window.
Chris
Help Us Help You
Chris
Pro Tools 2024.3
Focusrite LS56
Focusrite Pro40 (3)
Slate Digital VRS8
Analogue Tonebuss 24 Channel
UAD-2 OCTO Core Accelerator
UAD Volt 2
macOS 10.15.7
32 GB DDR4 RAM
NVIDIA GeForce GT 740 2 GB
Old 10-09-2013, 08:34 AM
BigJohnD BigJohnD is offline
Does your MIDI keyboard use a USB interface? You might check to see if the keyboard needs it's latest drivers installed. That is what kept PT 11 from recognizing my keyboard inputs. New keyboard driver fixed my problem.
Old 10-09-2013, 10:31 AM
Southsidemusic's Avatar
Originally Posted by cwsand View Post
Chris
Also make sure the "record button" is armed as you won't hear anything otherwise.
Christopher
Best Regards
Christopher
#thestruggleisreal
South Side Music Group
WEBHOME
PT11 audio dropouts when recording BFD3 and other virtual instruments yeloop Pro Tools 11 3 12-24-2013 04:45 PM
Virtual Instruments for PT11 visionstudios Pro Tools 11 2 12-24-2013 06:44 AM
PT11 with only 6 instruments??? MiaKAE Pro Tools 11 6 08-20-2013 05:18 AM
Missing Virtual Instruments: PT11 [solved] Paul Sombric Pro Tools 11 27 07-23-2013 01:30 AM
Avid Virtual Instruments for PT11 danika Pro Tools 11 2 07-02-2013 08:55 PM
