Importing multichannel wav?
I have a project coming up using a Sound Devices 688. It will record in a multichannel format as well as recording each channel on it's own wave file. If the project ends up being recorded as a polyphonic .wav file can I just drag it into PT or do I need to convert it somehow? Running PT 12.6 native non HD.
Thanks
Scott Auckland New Zealand PT2022.5 Focusright RedNET 8Pre, RedNET R1 Z690 AERO D Workstation, I7 3.6GHz 12 core, 64GB RAM, Win10 Business 64bit |
Re: Importing multichannel wav?
You should be able to import poly files no problem.
I can't imagine it being an HD only feature. |
I think multichannel is HD only, although I don't have a version I can check on. If you can't, sound devices wave agent can split multi's into mono files then you could import into PT12. It's free I believe.
https://www.sounddevices.com/product/wave-agent/ |
I use Studio One for this; Presonus doesn't charge extra to import audio!
-- Mike - HP Spectre x360 Convertible 14t-ea100 - 2.9 GHz (5.0 Max Turbo) i7-1195G7 32GB RAM, OLED 3k x 2k, Iris Xe Onboard Graphics - Windows 11 - PT 2021.12 - PreSonus Quantum 2 - PreSonus Studio 24c - Mackie Onyx 1640i - Samsung T3 and T5 SSDs - Various USB2/3 and Firewire HDDs |
It turned out last Friday I was able to import the multichannel file directly into PT12.6 non HD by dragging it into the session. In the end I ended up recording on a Sound Devices 788.
Scott, what did you do with it once you imported..were you able to split it into 6x mono?
I setup 10 mono tracks in PT and just dragged the .wav file onto the edit window and it split them out dropping one onto each track.
Just for laughs I tried it with an old version of Adobe Audition v3 I had and that worked the same. However Tracks Live gave me an import error.
Niiice, Good to know it can do it.
Importing Multichannel interleaved .wav file into Protools 9 | AndoNaught | Pro Tools 9 | 2 | 11-29-2018 11:09 AM |
No multichannel EQ? | Numi | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 10-23-2008 04:30 PM |
Multichannel tracks? | JonesH | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 06-15-2008 03:00 AM |
Any recommendations for a multichannel amp? | anodecathode | Pro Tools TDM Systems (Mac) | 11 | 06-06-2004 04:36 PM |
Multichannel panner in PT 5.1? | DigiTechSupt | Pro Tools TDM Systems (Mac) | 4 | 04-10-2002 11:42 AM |
