Disable Countoff Completely?
Hi--
I KNOW this is a dumb question, but I'm stumped & annoyed. I just did a complete reinstall of my OS (Mac El Capitan) and PT (11.3.1). Everything is working quite fine, EXCEPT that when I hit record, it takes a few seconds (basically a bar) before starting. Recording used to start immediately, before the reinstall. I'm sure I'm just not seeing it, but where is the option to disable countoff (for both record & playback)? (I found, under Click/Countoff, the option for countoff "only during record" and now playback is immediate. But there's still the annoying pause before record starts.) thanks ~peter in istanbul
* Macbook Air : M1 ~ 16gb ~ 1tb ~ Ventura latest * Hackintosh : i9-9900k ~ 16gb ~ 3tb ~ Monterey 12.6.1 * PT 23.6 + Ableton Suite 11.3 * Soundtoys + Valhalla + Fabfilter + Spitfire * RME Fireface UCX II ~ Arturia Keylab Essential 49 * various clarinets, trumpets, flutes, plucky stringy thingies |
Re: Disable Countoff Completely?
look on the transport
On the "expanded" transport.
~ 2019 Rack Mac Pro 3.2 GHz 16 core 384 GB RAM Catalina 10.15.7 / Pro Tools Ultimate 2022.12.0 / HDX 2 + UAD2 PCIe OCTO+QUAD / HD I/O's x 4 + 1 x 96io / Digidesign Pre's x 3 / Avid S6 M10-24 -V22.12.1.34 ~ ~ Mac Pro 8 core - clover - 13 GB ram - 10.6.8 / HD5 / Pro Tools 9.0.6 / Magma PE6R4 ~ ARCHIVE RIG ~ Mac Pro (Early 2009) - 2 x 2.26 GHz Quad-Core-32 GB RAM-10.13.6 / Pro Tools Ultimate 2019.10 / Apollo 16 / Avid S3 ~ |
Thanks for the replies guys, but nothing in the (expanded) transport helps. All there is there is pre/post roll, fade-in, and "transport online". I can't put transport online, getting an error "Pro Tools cannot be put online while in Countoff mode."
Perhaps this is a bug with PT 11.3.1 on El Capitan? Has anyone else encountered the inability to disable countoff?
I cannot remember if it's the same in PT 11, but at the top right of the edit screen in 12 is a small, downward pointing arrow. If you click on this a midi window will pop up. In this window de-select "Countoff" and you will have no delay on going into record.
Dell Precision 490 Workstation, dual 4 core 5355 Xeon, 16gb Samsung DDR2 ECC Ram - Windows 7 Ultimate - Nvidia GTX 650 - 3 x Internal WD Blacks - PT 2018.3 - Digi 002R - Original Mackie HUI - 3 screens - JBL Monitoring. Dell XPS 8700 i7-4790 - 24gb RAM - Windows 10 - Nvidia GTX 1060 6GB with Studio driver 546.01 - 2 x Internal Samsung 860 EVO SSDs, and MSATA card - Davinci Resolve Studio 18.6.4 - 3 screens - Blackmagic Speed Editor - MK1 Presonus Faderport - Canon C100 mk2 - Atomos Ninja 2 - Zoom H2n |
The second half of this video shows the countoff https://www.youtube.com/watch?v=f4s9LPkkg7k If that is not your problem, trash preferences.
Brian Windows 11 Pro | macOS 12 Pro Tools 2022 benonistudio.com Youtube Channel - benonistudio Plugin Deals @benonistudio |
Just to highlight what I was talking about.
You're on a PC, so I don't know if this would apply, but I used to see this behavior on a Mac. Seems that if you had system settings to input on line in, Pro Tools would have to switch to it's hardware every time you went into record, causing such a delay. On a Mac, you could set the system audio to Digital in or to the Pro Tools hardware and that would eliminate the problem.
It's been a while, so I don't remember if this was the exact problem, but I would check your Playback Engine settings to make sure they are on the correct hardware as well.
Save early and often! (or once a day whether you need to or not...) |
Having just re-read your system specs, I see that you have installed El Capitan. There have been problems running PT11 under El Capitan and it has only just been qualified for PT12.
Thank you Wizzoboy & everyone who chimed in. ~peter in istanbul
* Macbook Air : M1 ~ 16gb ~ 1tb ~ Ventura latest * Hackintosh : i9-9900k ~ 16gb ~ 3tb ~ Monterey 12.6.1 * PT 23.6 + Ableton Suite 11.3 * Soundtoys + Valhalla + Fabfilter + Spitfire * RME Fireface UCX II ~ Arturia Keylab Essential 49 * various clarinets, trumpets, flutes, plucky stringy thingies Last edited by huzzam; 11-22-2015 at 11:41 PM. |
Defeat countoff? | sw rec | Pro Tools 11 | 6 | 11-08-2013 01:37 PM |
Possible MIDI countoff bug? | Marsdy | Pro Tools TDM Systems (Mac) | 8 | 08-07-2013 07:07 PM |
no click during countoff | manyrains | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 09-11-2010 12:40 PM |
The countoff of the metronome | Push-Pull | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 01-14-2008 10:20 AM |
countoff problem | jpj | Pro Tools TDM Systems (Mac) | 1 | 08-22-2005 09:53 AM |
