Re: I don't feel so ripped off anymore
so what software would you buy next?
Mac Mini 2.4 5GB Ram Pro Tools 9 Logic X KORG Triton Extreme |
3930K I7,X79 asus,GTX780,Samsung SSDx2,Western Digital Black 2TB HDDx4 32 Gb Corsair ram,30"Apple Cinema Screen,HD NATIVE |
maybe steinberg cubase .. been trying out on a real loser machine a 256 megbyte of ram single core outdated but it runs huge amounts of vst plugins as well as it plays back 24 tracks without a hitch .. hadn't tried to record as all i have is the alesis 2 channel a i/o hooked up but thinking about hooking my motu 2408 and see how many tracks i can manage which will be 24 if it works ..if cubase can do this on a cheap all i use for is internet machine then I may take off pro tools and install on my main machine . the bad thing is that i use a lot of the McDsp and waves plugins and the McDsp do not have vst option which i will not be able to use. i dont use a lot of the pro tools plugins except for revibe and reverb one .
Hi Everyone,
I haven't been here for a long time as I have been so busy with my label and artists etc. On my return, I have been surprised to find all this negativity towards version 8 on PC. I simply updated to 8 and recently to 8.01 and haven't had any unusual issues. Not trying to create any havoc here at all just stating my experience. I am running a PC with DIGIDESIGN 32 bit Chassis (have to upgrade that soon I know!!) Running HD4 (PCI cards) with DIGIDESIGN Plugs as well as third party such as McDSP. Also use the FXPANSION wrapper, BFD, Native Instrumentents scarbee pre bass, Sample Tank AND MANY OTHERS. Yes I have had a couple of glitches with the MINI GRAND loading strangely and dropping notes occassionally, but all else seems to be fine. The one issue I have had even before PT8 is that my RAM gets heavily used with the Plugins such as BFD, and NAtive Instruments etc so If I close a session I do sometimes have to reboot to flush the RAM as it won't load all the samples needed for the next session sometimes after I have been running a heavy VI session. Anyway, just wanted to let you all know my experience. All the best, Big D
INTEL QUAD XEON INTEL S5000XVN serverboard 4 gig Fully Buffered Ram (About to add more) 3 x WD500gig SATA, 1 x WD1T32mb SATA cache Green NVIDIA Geforce 7300le, Command 8,HD2,192,Massive Pack 4 Windows 7 64 bit PTHD 9 |
Gravyblue. I'm not sure this applies to your tech support or CSA ticket but thought I would relate this little bit.
Back around Dec or so I inquired several times about the MPTK2+DVTK2 to CPT upgrade and received a couple of "We haven't got a response from you so were assuming your tickets closed" type of email response. Logging in to check the support ticket would show that nothing had changed. Finally after the 3-4th visit I figured out that you needed to scroll up to see Digi Cs's response. Very counterintuitive. I mention it because something similar may be happening in your case.
Scott Formerly Hobo Wan Kenobi Core 2 Specs Page ASUS P6T6 Revolution | i7 930 | 12GB OCZ DDR3 1600 7-7-7-20 | PTLE 10 | CPTK | 003 | Presonus D8 | 11Rack | Alesis AI3 | Presonus HP60 | Mercury + Studio Classics | Sound Toys | MasseyPack | Axiom61 | MAudio Keystation Pro 88 |
#16
Thanks Sunburst, but I can't find any reference!
#17
Last night I recorded a flawless 7.4 session for over 4 hours using the mini grand and a handful of the Air plugs among others.43 tracks,cpu stayed low(about 28%),AND NO FREAKIN ERRORS WHATSOEVER DIGI!
Guys who can't run a professional session with PT 8 I urge them to go back to 7.4 and utilize 8's plugs and VI's in 7.4.Your headaches should disappear once and for all.BTW......i'm on 7.4cs10.
Bug ridden Pro Tools 8 but back to 7.4 HD2,192 I/O,96 I/O,Midi I/O,Control 24 |
#18
hey meat, no errors you say?? this is not normal operation, something must be wrong with your system
#19
In the world of Pro Tools HD you may be right.8's plugs and VI's were worth the $249 upgrade to PT8.......just throw the worthless 8 into the garbage and keep it's plugs and ya might not feel RIPPED OFF anymore.I do miss those 10 inserts.Nothing I can't easily get around though.
#20
Feel totally ripped off | ahjteam | Pro Tools 10 | 7 | 11-01-2011 03:06 AM |
did I get ripped off? | nandk | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 09-04-2008 07:41 AM |
Structure Upgrade: I've been ripped off!!!!! HELP Digi CS!!! | RobMacki | Pro Tools TDM Systems (Mac) | 2 | 07-16-2007 11:11 AM |
did i just get ripped off??? | AM STUDIOS | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 15 | 04-14-2005 09:25 PM |
Have U been ripped off? | tworooms | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 06-28-2002 08:56 PM |
