Waves Tune vs Melodyne Bridge
Just interested in current opinions on these two 'plug-ins'.
Tune is a great concept although I've had a play for an hour and am not convinced by the sound quality so far, it sounds a little 'synthy'. Read great things about Melodyne, haven't tried it yet; although workflow does not look as slick as Tune's. Anyway, feedback would be appreciated. Thanks.
Rig: Softw: PT7.1.1cs5, OSX10.4.5, hardw: G5 (2003) 2x2Ghz, Digi 64bit Chassis, HDAccelx5, i/o:2x192, 1x96, 2 x888/24, 2xADATBridge. |
Re: Waves Tune vs Melodyne Bridge
Melodyne works great, far superior to anything else available, but does require a learning curve!! you can't just transfer into melodyne and press 1 button to fix, you often have to cut the waveforms where the pitch changes are manually and move them around a bit, but the end results can be miraculous. Chris
This is a cop out answer, but both are great and have their advantages.
Melodyne's amazing in that you can fill your whole screen with its interface and perform virtual miracles. Waves Tune I find better when you want to just paint in the right notes. Sometimes on the front of a word if the singer just blew it, you can paint in a straight line with Waves Tune and then add a touch of its artificial vibrato and the results seem to be cool every time. You can't lose with either of these and it shows that we've really moved along in this area in the last few years.
Cool & Informative Video Tutorials from Groove3 |
Waves Tune is the king of tracking difficult material. I mix a fair bit of live Music, and Tune does a great job with vocals that have a lot of trashy leakage. Nothing else tracks nearly as well.
I use Melodyne when I want to groove vocals or make sure vocals are moving in perfect sync with other vocals, both pitch and timing. Melodyne is great for creating harmonies. For straight up tuning jobs, I prefer Waves Tune. STeve
macmandigital.com |
Thanks for replies. What do you think of Tune's 'sound' though? I thought it sounded a bit grainy especially on formant corrected mode, but maybe I need to tweak it more...
And do you find Melodyne Bridge works now in PT7 - I noticed people were having problems a few months ago?
I used Tune daily for about two months. I was so impressed with it over, ahem, the former tuning champion plug, that I overlooked its flaws. Then I tried the fantastic Melodyne 3, and haven't touched Tune much since. But Tune really is a great plug.
The only problem that I hear with Tune is I believe created by its default correction settings. It tries to correct every single note to whatever key the song is in, whereas Melodyne doesn't change anything unless you tell it to. If you make Tune only change things that bug you in the performance, you'll have far less grain and synthetic-ness. Turn those knobs all the way down and then start, and you'll have a much better sounding result. As far as Melodyne playing nice with PT7--well, Melodyne crashes at least twice a day for me. I save about every minute now. But it does what it does perfectly. |
Captain Crunch thanks; I take 'on board' the point about less-is-more, I'll try it with less correction.
I noticed one major thing with Tune though, and that is it can't handle tempo changes on the timeline. It glitches the audio every time there is a tempo change, and it doesn't have to be a big tempo change to do this, it can be a very small change; that is quite a disappointment.
My experience was somewhat opposite of another post, where I was always using Melodyne until I discovered what Tune can do. It was a big motivation to stay with-in ProTools. STeve
macmandigital.com |
I think the tempo thing is a known bug. The short term fix is to copy to audio into another session with no tempo changes and then export the fixed version back again. Not ideal, but it works.
I use Melodyne with ReWire. The Bridge doesn't sync well with Pro Tools and the transport functions are a bit funky. With ReWire, even though, as another post mentioned, it crashes fairly frequently, it works and sounds great as long as it is running. As long as you save often it's not that big of a deal to reboot it quickly. As was also mentioned, it is amazing for matching phrasing of lead and backup voc's. Pretty damn cool tool. |
waves SSL 4000 v9 , PT9 , melodyne editor, auto tune, 11 LE, iLok | mesa3077boogie | Buy & Sell | 2 | 08-17-2013 02:41 PM |
Waves Tune v Melodyne - quality? | JazzyJ | macOS | 3 | 12-21-2011 10:19 AM |
Waves Tune V Melodyne - quality? | JazzyJ | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 12-20-2011 03:27 PM |
Melodyne Studio 3.2 Bridge not communicating with Melodyne -- help! | nuggitz | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 07-08-2009 03:02 PM |
Waves Tune vs. Melodyne | Ricky Cobble | Pro Tools TDM Systems (Mac) | 4 | 11-16-2005 11:26 AM |
