Old 10-17-2018, 11:42 PM
wildplum wildplum is offline
Default Asio driver and non Pro Tools software
My question concerns the ASIO Digidesign Driver, Windows 7 and four programs: Pro Tools HD version 8.1.1, WaveLab 6, RX 6 , and HOFA.
My old machine, a Windows XP machine, died and I got a new (for me) machine running Windows 7. I use a 192 i/o and a 96 i/o connected to a Digidesign HD accel core pcie card. All four of these programs ran fine on the XP machine using the ASIO driver that came with the HD version 8 install CD.
Then I installed the four programs (and their respective license dongles).
Pro Tools HD installed without too much difficulty and runs fine; same with WaveLab.
Both RX6 and HOFA installed and launch just fine. However, neither of them recognize the ASIO Digidesign Driver as a playback option.
I have drawn a total blank on how to fix the problem.
Any help or advice would be much appreciated.
Thank you.
Paul Tumolo
Wildplum Recordings
a micro label, studio and remote recording service
Old 10-18-2018, 04:57 AM
Neil H Neil H is offline
Default Re: Asio driver and non Pro Tools software
Its not going to work, its been a very long in the tooth subject but Avid never showed any interest in fixing it.
You best chance is to get a cheap 3rd party audio interface and wire it to your monitoring for all non PT tasks.
Pro Tools 2019.5 Ultimate
Windows 10 Pro
Join the Facebook Pro Tools Windows User Group
Old 10-18-2018, 08:46 AM
thank you Neil. Is this a problem unique to windows 7? The same group of 4 programs worked with windows XP. There was a different ASIO digdesign driver involved (I think) but all 4 programs happily shared that driver.
And why does WaveLab work (it successfully uses the Asio digidesign driver in my new environment), but I can not get RX and HOFA to even recognize the driver as present. very strange.
Paul Tumolo
Wildplum Recordings
Old 10-18-2018, 12:54 PM
HD Core/accel were never supported for anything beyond Windows 7 so thats where that hardware ends but FYI yes its still the case if you were to try it.
The problem also exists for HDX and HD Native cards with Windows 7, 8, and 10.
I don't think Avid have shown any interest in their hardware working for anything but PT for many years now.
Why does it work in wavelab? luck that wavelab is a little more tolerant perhaps, either way the situation is not going to chang/improvee as HD TDM hardware is now long out of support and development.
Windows 10 Pro
Old 10-19-2018, 09:51 AM
Neil, one last question if I may, please.
I have an option to replace PT HD 8.1 software with PT HD 9 on my windows 7 machine (same HD accel core, 192 amd 96). Can I expect to have the same problems running non avid soft (e.g., RX) using the ASIO that come with the HD 9 install disc?
BTW, part of the reason I am still on old stuff is that I only use PT for recording and editing; i mix analog.
Thanks again, you have been very helpful.
Paul Tumolo
Wildplum Recordings
Old 10-19-2018, 10:02 AM
Yes I'd expect the same problem from any later version.
Windows 10 Pro
PT 11.3 HDX Asio Driver and 3rd Party Software stevenraets Windows 3 08-25-2017 10:51 AM
FL7 PRO TOOLS 7.4 LE[ASIO DRIVER ERROR IN FL7. vetsquad muzik 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 02-17-2008 09:06 AM
Asio driver problems with 002 Pro tools 7 with SP2 inka 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 06-03-2007 09:01 PM
PRO TOOLS 7 ASIO DRIVER PROBLEM instro001 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 12-17-2005 08:57 AM
asio driver pro tools 5.1 ?? Possible ?? nossnevs 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 01-12-2004 03:44 PM
