Old 04-17-2017, 03:22 PM
PTPerson PTPerson is offline
Default Re: Where can i buy a Power Supply for my D-Command ?
I used to own an SSL 4072 and a Euphonix CS3000.
PSUs were always going down.
Old 04-17-2017, 04:34 PM
YYR123's Avatar
YYR123 YYR123 is offline
Originally Posted by Drew Mazurek View Post
Or if you're "on plan", you can simply start a case.
Yes, the first action....make them earn that support money !!!
Daniel
Old 04-17-2017, 04:45 PM
Drew Mazurek's Avatar
zackly.
www.drewmazurek.com
Old 04-26-2017, 09:41 AM
francois's Avatar
francois francois is offline
got the new power supply in the mail today
That's when the board starting to stop flashing ....
It took the fader pack about 10 days of power up to fix itself
I'll keep the PS handy
PT 2023-12 ultimate -HDX1- OSX 13.6.1- MacPro 7.1
- D-command 24- Trinnov Dmon6
Old 04-26-2017, 09:50 AM
Southsidemusic's Avatar
Thanks for the update.
BTW This morning one of Our SSL4000G+ PSU stopped playing nice (typical) and we ordered a new old stock which was super pricey, well they both were but we NEED that unit to run all day every day so ..
Best Regards
Christopher
#thestruggleisreal
South Side Music Group
WEBHOME
Old 01-09-2019, 04:34 AM
ssl4000 ssl4000 is offline
My D-command main unit started to flash today! Its a big problem. Do the fader pack still work without a new power supply??
Old 01-09-2019, 08:20 AM
If it's just the display LEDs flashing then it's probably just the LED supply - faders will continue to work, but display may go out entirely so you need to fix it!
http://www.richbreen.com
Old 01-24-2019, 12:37 AM
Jeezer Jeezer is offline
Before spending on PSUs, check the capacitors (usually these fail first on PSUs) you could feasibly end up replacing them (soldering in new ones) for mere pennies vs the hundreds for the PSU.
Waste not want not.
Old 02-28-2019, 04:00 AM
andrej770 andrej770 is offline
Waste not want not.
I beg to differ. If you spend good money for these consoles, why go cheap, and turn into Mr. Fixit, when they need repairs. Who has time in the middle of a mix to solder a capacitor? And which is the correct capacitor to replace? And what if the capacitor going bad was a sign other parts of the PSU need to be repaired? This line of questioning could continue...all along your console is unavailable for sessions.
In this business time is money and console availability is money. Spend the $100 on the PSU's from Sager (Search the forums for other posts I've made) and replace the PSU. The old PSU isn't going to have a bubble comment above the bad capacitor guiding you along. I have spare PSU's for each possible failure. Save up and do the same. These consoles are no longer supported AT ALL by Avid. It will save you time and money in the end...and keep your console available. You tube can teach you how to replace the capacitor but it won't re-earn the money you lost while tinkering with the consoles delicate electronics.
Just MHO.
Mac 8 Core 6,1 - OSX 10.13.6 - 32GB RAM - Pro Tools 2018.10 - 8x8x8+8 ch DA Card (x2) - HD OMNI - ICON D-Control 32 - Sync I/O - Sonnet xMac Pro Server w/HDX x 2, Blackmagic Intensity Pro 4K
Protools 2018.10 HD Native in 1 project suite
Eristopher Music
Old 02-28-2019, 07:25 AM
BScout BScout is offline
Just MHO.
Sounds like someone's afraid of a solder gun. Or has never fixed a power supply.
The capacitors are the only things that go bad on these power supplies.
And yes, there is practically "a bubble" marking the problem. The bad capacitor is expanded (blown up) and sometimes with burn marks. Pretty easy to tell. Here in Los Angeles, you can get an "advanced replacement" which pretty much means you pickup a power supply, swap it in, and take the broken one back to get repaired.
As for "cheap" -- paying more to someone else for a cheap power supply at a a higher price does not make the fix more professional. It's the same problem fixed the same way. There are multiple power supplies in a D-Command, keep a spare of each. It takes longer to get to and unmount the power supply than it does to swap a capacitor.
Pro Tools Ult 2024.3, HDX 2, MTRX/SPQ, RME BBF Pro + MADIface Pro • S1 x 2, Fire HD10 + Max11, Dock, iPad Air5 • Mac Mini 14,12, 12 core, macOS 13.6.5 • RAM 32GB, SSD 4TB, GPU 19 core • QNAP TVS-872XT 148TB TB3
Command 8 Power supply davpond Buy & Sell 2 12-06-2019 08:06 AM
Command 8 Power Supply question MarkH ProControl, Control|24, Command|8 6 09-20-2017 05:11 PM
Command 8 Power Supply SWAP US for EU psmworld ProControl, Control|24, Command|8 1 09-03-2015 11:29 AM
Command|8 Power Supply? stuseattle ProControl, Control|24, Command|8 5 05-03-2012 04:33 AM
Command 8 Power Supply infernojs ProControl, Control|24, Command|8 3 10-03-2005 12:59 AM
