Old 01-13-2007, 06:21 PM
b mcgibney b mcgibney is offline
Default Help! Error #-5000 while verifying your authoriza
This is a continuation of my previous post. Running Disk warrior and indexing my hard drives buggered everything up. I've nearly got everything working except I can't get my waves NPP 5.0 to authorize. When I fire up PTLE 6.4 I get this error #-5000 while verifying your authorization. I even tried wiping a disk clean reinstalling the OS and a fresh copy of PT and still the problem persist. I have WUP and an ilok. Any ideas on how to clean up this mess.
Brian
2010 Mac 5,1 32 GB Ram. PT 2018.12. Mac OS 10.12.6. RME UFX and lots of noisemaking stuff
Old 01-13-2007, 06:43 PM
Forum Member LE Forum Member LE is offline
Default Re: Help! Error #-5000 while verifying your authoriza
Your disk permissions are still not correct.
You may have to manually set your access and they select apply to all items.
The errors and lack of ilok comes from it not seeing you as someone with full access rights.
On the iMac I have whenever I do a repair disk permission with the disk utility I have to go back and set things the way I need them manually.
What the disk utility does causes me to have issues.
Old 01-13-2007, 07:46 PM
How exactly do I go about manually resetting the access and then have it apply to all items?
A little deeper than I've gone before
TIA Brian
Error #-5000 while verifying your authorization. (Air Plugins) jiveman 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 02-03-2010 01:19 PM
More fustration!! Error 5000 while verifying authorization carpmusic 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 03-26-2009 10:21 AM
error 5000 unable verifying author? on pro tools pro tool degree 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 08-21-2004 03:35 AM
Error 5000 while verifying authorization SNAZ Pro Tools TDM Systems (Mac) 4 02-02-2004 08:50 AM
Error 5000 while verifying authorization Bezo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 08-01-2003 07:54 AM
