Old 07-13-2003, 01:01 PM
Bastiaan Bastiaan is offline
Default Re: Clocking Problem Fix...
You have the option to change the samplerate when you do a "save session copy in"(file menu). It will take some time for sure, but then the whole session will be 44.1 Khz (or more precise: a copy of the session). Make sure you check the box to copy all audiofiles.
What's that?
- That's the machine that goes "pling".
Bastiaan
Old 07-13-2003, 02:34 PM
Chris Cavell Chris Cavell is offline
I would also set your settings for conversion to "tweak head" when you do this. It makes a difference.
Cavell Studios
Old 07-14-2003, 12:17 AM
mfym mfym is offline
Default Clocking Problem Fix...
I have three sessions that were recorded at 24/48000, and I need to them as 24/44100. I have a piece of outborad gear that will only run at 44100 and so there are many pop and ticks during playback.
I have thought I could BTD the audio files, one at a time, and put them back into a new session at 44100 (two conversions). Is it possible to simply import them into a new session at 44100 and would PTLE do the conversion correct, so I wouldn't have to BTD?
Also, one of the sessions is midi only. If I create a midi file and import it into a new 44100 session, would the timing be correct or would the midi file play too slow?
I'm basically wanting to save myself all the testing work cause I know there has to be way to revive the sessions as 44100, so any advice is appreciated.
[img]images/icons/rolleyes.gif[/img]
Clocking Problem???? mybrother 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 01-12-2010 01:09 PM
003 clocking problem rowchar 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 05-21-2008 10:44 AM
Clocking problem with 96 i/o DonovanBomb Pro Tools TDM Systems (Mac) 0 08-14-2007 07:27 PM
Strange clocking problem? locosoundman 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 09-03-2005 06:21 AM
Clocking problem? Please help kurt Pro Tools TDM Systems (Mac) 4 09-11-2002 12:03 AM
