Go Back   Avid Pro Audio Community > Pro Mixing > Avid S1, S3, Dock and Control
Old 10-27-2016, 06:10 AM
simonchase simonchase is offline
Default SOLVED - Dock Left Edit "Shift" greyed out
None of the "alt" features are working on my "Dock Left Edit"
I can assign the functions to other soft keys on the dock. And the normal functions work as expected.
If I go to manually assign them in the EuControl settings Soft Keys page, I can't select the "Shift" check box as it is greyed out.
Any ideas?
PT Ultimate 2020.3 - MacOS 10.14.6 - Mac Pro (Mid 2010) - 2 x 3.46 GHz 6-Core Intel Xeon - 48 GB 1333 MHz DDR3 RAM - SSD Startup Disk - Radeon RX 560 - AJA Kona LHi PCIe - Apogee Quartet
Old 10-27-2016, 07:24 AM
gwhatley's Avatar
gwhatley gwhatley is offline
Default Re: Dock Left Edit "Shift" greyed out
Try changing the"page" to 2 in the drop-down menu on the upper left side. (Not looking directly at it, so my wording may be sightly off).
Sent from my LG-H830 using Tapatalk
Garrard Whatley
Seismic Post Audio
Post Audio for Film and Television
System/Hardware Info
IMDb credits
Old 10-27-2016, 08:58 AM
Page 1 is the only option
Old 10-27-2016, 10:14 AM
gwhatley's Avatar
Very strange, my "Dock Left Edit" has a page 2 option. My Eucontrol version is 3.5.0, but the appsets are the same latest version 1.2 from May 2016. Yours any different?
Garrard Whatley
Seismic Post Audio
IMDb credits
Old 10-28-2016, 06:05 AM
Someone sent me a replacement xml file and that did the job
Old 03-14-2017, 11:50 AM
WinstonDeath WinstonDeath is offline
Default Re: SOLVED - Dock Left Edit "Shift" greyed out
Exact same issue for me, with EuCon 3.5.0
Did you have to start from scratch with all your personalizations in EuCon with the replacement .xml file?
Exporting Midi - "Location Reference" Option Greyed Out...sometimes... Sparky1 macOS 3 06-09-2016 11:07 AM
Alt-Shortcut to reach "Edit" > "Automation" > joachim Windows 0 10-13-2014 08:14 AM
"Space" in Edit Window, to the left of Bar 1 ?!? LSNY macOS 1 05-29-2012 07:47 PM
fades link is "greyed out" can't click to access them Daviat 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 07-19-2011 02:34 PM
Error 7053, "Wm exception". "TDM ProcessTypeGlues"(!) and SoundToys greyed out ! LSNY macOS 1 02-08-2011 04:16 PM
