Old 03-05-2016, 10:08 AM
AlainZagar AlainZagar is offline
Default Application Manager 15 million files and 104 GB
Hi all,
I thought I would share this as I've seen quite a few posts related to systems slowing down if the Application Manager is running.
Application manager seems to be creating folders beginning with names like "Jetty...." and lots of sub-folders in my Temp folder on my Windows 10 system.
Each "Jetty" folder contains roughly 45 MB of files.
I had about 15 million files in a several thousand sub-folders with file names related to Avid and totaling 104 GB.
This is on my primary boot partition and it is a SSD.
I disabled Application Manager and the folders stopped appearing.
Enabled and it started to recreate these same folders so I'm pretty certain these folders are related to Application Manager.
Seems to be related to third party software that Avid is using from ej-technologies.
System is working perfectly fine and stable at 12.4.0 and I have the latest application manager 2.5.2.160 installed so I can leave it disabled.
If anyone on Windows 10 is experiencing performance problems and is running Application Manager then perhaps try to search for folders that begin with names like
jetty-0.0.0.0-1696-AvidApplicationManagerHelper.war-_-any-6839863891320020635.dir...
Consider disabling this software if you don't need it.
cheers
Old 03-05-2016, 10:49 AM
ChuckS ChuckS is offline
Default Re: Application Manager 15 million files and 104 GB
The whole Java thing leaves me wondering . . . Anyway you can also use something like CCleaner (http://www.piriform.com/ccleaner) to clean up the mess if you don't want to disable or uninstall the App Manager.
PT 2020.5 DP 10.11 VEP 7.x MOTU M4 HP Envy 8G i7 Quad Laptop Win10 (x64 20H2)
PT 2020.5 DP 10.11 VEP 7.x 828mkII ADA8200 MTP-AV 2011 Mac Mini i7 Quad High Sierra.6
Old 03-05-2016, 10:52 AM
john1192 john1192 is offline
is this PC only .. i searched for Jetty on my Mac but nothing comes up .. does this happen when you are logged into to avid account via App manager or when not even logged in ??
Mac Pro 6-core 3.33ghz (2012) 24gb ram 256gb SSD -OS 10.12.6 for PT 11.3.2 & 2019.6 last version
Logic Pro X latest version
RME BabyFace Pro
Macbook Pro july 2014 2.5ghz 16gb ram 512gb SSD - OS10.14.6 - PT 2019.6 Ended here ..
RME BabyFace Pro
Old 03-05-2016, 10:57 AM
jeffro's Avatar
jeffro jeffro is offline
Do you have any of the options for Automatic/Updates/Downloads enabled within Application Manager?
Old 03-05-2016, 11:09 AM
Hi - I'm logged in, and it's on a Windows 10 Professional system and the settings in Application Manager are
Notifications
- Show Apps ( checked )
- Show Feeds ( checked )
Allow Data Collection ( unchecked )
Administration
- Allow Admin Functions ( checked )
- View Activity History ( unchecked )
Updates - (not automatic)
Downloads - (not automatic)
In the 3 minutes it took to reply to this post, it added 1gb of files in the temp folder.
Old 03-05-2016, 11:15 AM
jeffro's Avatar
Thanks for that additional info, logged it for Engineering to review. Anyone seeing this on Win7 or Win8/8.1?
Old 03-05-2016, 03:40 PM
seanmccoy seanmccoy is offline
Windows 8.1 here. Not seeing anything like this. My workstation isn't normally online, and I have everything unchecked.
ADK Core i7 4.20, 32GB RAM, W10 Pro, PT HD 2020.5, HD Native, OMNI, Digi 192, AJA Kona LHi, UAD-2 Octo; Mac Pro 12-core 3.46, 64GB RAM, Mojave, Logic Pro 10.5.1, Apogee Rosetta 800, UAD-2 Quad, MOTU 2408 Mk II: MBP mid-2012, 16GB RAM, Mojave, MOTU 8-Pre-ES, Pro Tools 2019.10
Old 03-05-2016, 05:36 PM
The Weed's Avatar
The Weed The Weed is offline
Recently, I just disabled App Manager and App Helper in Task Manager. I'd already signed up for Technical Alerts. I had no issues, but, given PT's crankiness, I try to have as little as possible running in the background.
Another thing to disable is Application Experience in Services.
Cheers,
non-union national read at a reasonable rate
Demos: brucehayward dot com
Source-Connect: brucehayward
Old 03-06-2016, 12:29 PM
ThoBre ThoBre is offline
Same here on WIN7. Seems like the AppManager creates a folder named something like "Appman_Jetty_..." in the users temp directory with hundred thousands of .class files at every start of Windows.
Old 03-07-2016, 02:53 AM
cu74 cu74 is offline
Same here... Win 10 Pro (64 bit)
Can't Log In to Application Manager Josh523 Pro Tools 12 3 08-21-2016 08:44 AM
Application Manager not showing downloads for license deposited into iLok account Tjrasulo Pro Tools 12 2 02-20-2016 01:23 PM
Application Manager? jandue Pro Tools 12 2 12-11-2015 12:05 PM
Application Manager 2.4.4 unkJE Pro Tools 12 8 10-14-2015 01:56 PM
Application Manager hooksound Pro Tools 12 0 04-08-2015 10:00 AM
