Old 11-16-2014, 07:00 AM
princeplanet princeplanet is offline
Default Confused about HDX i/o
Hi guys, I tried to find this out first before asking here, but can't get the straight dope anywhere, so here's my question: How many simultaneous physical inputs and outputs can I achieve with a single HDX card? I have a feeling it's 32 ins and 32 simultaneous outs.
If so that's a bummer, as I'm thinking of finally upgrading to a Mac setup from my old PC running PT8 with HD3 PCIx cards and 3 x Lynx 16/16 converters which are currently providing 48 ins and 48 out simultaneously (which i need),
How do I work out what I'd be up for $$ wise? If I trade my HD3, (can I keep the 3 Lynx boxes?), buy a new Mac as well as the software and the HDX card, how much is that? - after the trade in? And if I'm still 16 ins and 16 outs short of what I need, what's the answer? Another HDX card? Is that too expensive, and overkill?
Oh, and what's the skinny these days with the plugin compatibility? All my TDM's and RTAS, VST's etc no good?
Sheesh, this is gonna cost me a fortune, just to get back to where I was (er, am...). Am I sure I wanna do this?
Old 11-16-2014, 07:04 AM
Drew Mazurek's Avatar
Default Re: Confused about HDX i/o
http://duc.avid.com/showthread.php?t=340031
www.drewmazurek.com
Old 11-16-2014, 07:18 AM
JFreak's Avatar
JFreak JFreak is online now
The old HD cards had one DigiLink port per card, the new HDN/HDX cards have two ports. One DigiLink is 32 i/o.
Generally speaking, i/o count has doubled every generation. Current ones (HDN/HDX) are 64 i/o per card, previous (HD) were 32 i/o per card, blackies (MIX) were 16 i/o per card. Nobody even remembers anything pre-MIX (year 1998 or so)
Janne
Old 11-16-2014, 07:56 AM
Thanks, but 64i/o is only 32 ins at the same time as 32 outs. I need 48 of each, what's the solution?
Old 11-16-2014, 08:16 AM
JFreak's Avatar
Nope, it is 64 i/o as far as HDX1 card (or HDN) is concerned. But you would need interfaces that can do it, obviously something other than OMNI :)
Janne
Old 11-16-2014, 08:56 AM
Emcha_audio's Avatar
4 inputs
Manny.
Old 11-16-2014, 09:43 AM
DetroitT's Avatar
DetroitT DetroitT is offline
3 x Lynx 16/16----
Two off one port and one off the other.
Still room for one more set of 16 ins and outs.
Keep in mind the newer digilinks are smaller-pin sets than the older version.
So some adaptors/cable may be needed. (One comes with an HDn/HDx card)
(Help us Help You)<<<click here
APFS 90% 10% Audio on Both.
Pro Tools U-2020.5 macOS 10.14.6 APFS
Second boot-macOS 10.13.6 (Avid HDX-1 Omni)
(2k10MP 5,1 / 64-Gb)
(Sapphire RX-580 MVC-Edition-dual mini 6 pin. one spliced to add Avid mini 4 pin-hdx)
FW-CoreAudio (for poly-recording)
(SSL-HUI-MIDIoverIP)
music-design-creation
Post Music-Sound mixing, Production-Enhancements.
Audio Tuning and System Services
new systems builds / upkeep / +
New builds:
12 core nMP HDX 1 Slot 5 stock HDX Mac mini 6pin to 4 pin HDX power like 5,1 mp's used)
16 core nMP rack-test station
28 just because machine
Old 11-16-2014, 11:15 AM
Eduardo Apolonia Eduardo Apolonia is offline
As already said, each HDX card can support up to 64 inputs and 64 Outputs at the same time.
I have an HDX2 and I'm using a total of:
112 Outputs (80 Analog + 32 Digital)
100 Inputs (68 Analog + 32 Digital)
All at the same time.
Old 11-17-2014, 08:40 AM
Thanks everyone. No longer confused! ... Well, at least not about the number of i/o, so Lynx Aurora are working ok with HDX? That's good to know. Another thing I don't know is the maximum number of i/o on a HDN system?
Old 11-17-2014, 08:58 AM
Craig F Craig F is offline
well lets see, 32 i/o per digi link port and 2 digi link ports on a HDN card
and on HDN card can full access all 64 channels of the MADI interface so:
a) 64
b)
PT11 System Requirements link http://avid.force.com/pkb/articles/C...m-Requirements
Thank you,
Craig
Confused and need help bad joeystats Windows 5 04-18-2012 02:15 PM
A Bit Confused DJKeys macOS 1 08-16-2011 09:49 PM
:confused: Confused Re: Expansion Chasis BA Studios 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 02-26-2008 08:24 AM
So confused Pete Evick 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 08-20-2003 05:01 PM
Confused???????? Damage 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 11-06-2001 09:40 PM
