Old 04-08-2013, 08:38 PM
AlainZagar AlainZagar is offline
Default Command 8 and PT11 - untested?
Hi - Anyone have any thoughts on Command 8 still working correctly in PT11?
http://avid.force.com/pkb/articles/c...nd-Peripherals
Above link implies that it's untested but sounds odd. How can AVID not know if the drivers will work or not?
Alain
Old 04-25-2013, 01:04 PM
pcmusicpro pcmusicpro is offline
Default Re: Command 8 and PT11 - untested?
Well I´d like to know that too. Because if it wont work then I´d better sell it right now.
Old 04-25-2013, 01:46 PM
nigelpry's Avatar
nigelpry nigelpry is offline
Not supported = Avid can't be bothered testing it, because the product is EOL and why would Avid carrying on supporting it, and if Avid did find a problem they'd probably be expected to fix it so they won't even test it ... blah blah blah.
That's it basically, anything that Avid says is not supported is simply stuff they have not included in the testing scheme. It may work, and then again, it may not.
As opposed to the 'will not work' section, which means they have tested it (presumably hoping that it would get into the supported list) only to find its broken. And they are not prepared to invest the time and effort required to produce a fix.
Mac Pro 2009 with 2010 firmware, 12-Core 3.46ghz, 64gb RAM & working Thunderbolt, OS 10.14.6 and Windows 10
Macbook Pro 2011 17", 2.2ghz i7, 16gb RAM OS 10.12.6
Digi 003 Console, Focusrite OctopreLE and MOTU Traveler for extra analog-ADAT conversion, UAD Apollo Quad Silver with Thunderbolt card, Apollo x4 and pci-e Octo, Adam A77X monitors.
Pro Tools 2020.3, Media Composer 8.9, Sibelius 8.7, Cubase Pro 10.5, Wavelab Pro 10, Logic Pro X 10.4.8, Mainstage 3.
Various apps, soft synths, FX plugins.
Plenty of hardware synths, rack gear, microphones etc.
And then there's the studio ;-)
Old 04-25-2013, 08:12 PM
This let us with the "try and error" test. Gotta wait until PT11 is released and someone checks Command 8 functionality with the newest PT version.
Command 8 PT11 Jon Webber 117 ProControl, Control|24, Command|8 19 01-31-2016 09:23 AM
PT11 to PT11 HD Native upgrade without hardware? kirkbross Pro Tools 11 2 11-04-2013 03:10 PM
PT11 Doesn't Recognise D-Command davemurphy ICON & C|24 5 07-20-2013 08:50 AM
Plug-in mapping on D-Command w PT11 ?? SOUNDDECISION ICON & C|24 4 07-06-2013 01:09 PM
Plug-in mapping on D-command w/ PT11 SOUNDDECISION Pro Tools 11 0 07-05-2013 07:24 AM
