Old 12-07-2011, 10:15 AM
guitarman6 guitarman6 is offline
Default VI (specifically Mini Grand) Volume Level Problem / Issue
Recently when using certain VI (i.e. Mini Grand, Omnisphere, some Native Instruments) in the middle of playing the volume level drops to near zero (-53.1db for example with Mini Grand). It not happens when running playback, but also when sitting idle for a few minutes without being played the volume level will jump down.
I checked all obvious things such as automation that might be running in the background and have found nothing.
Does anyone know a fix for this?
Thanks in advance as always for your help and ideas.
Studio: Mac Pro 2 x 2.93 GHz Quad-Core Intel Xeon w 16 GB 1066 MHz DDR3 RAM running OS X 10.8.5 using Pro Tools v10.3.9 & v11.3.2 HDX w/ AVID HD I/O
Mobile: MBP Retina 2.6 HGz Intel Core i7 w 16 GB 1600 MHz DDR3 running macOS Sierra Version 10.12.5 and Logic (and LOVING IT!)
Old 12-15-2011, 01:38 AM
Becharax's Avatar
Becharax Becharax is offline
Default Re: VI (specifically Mini Grand) Volume Level Problem / Issue
When I started reading your post ... first thing that came to mind was automation ... Just try to run a blank session from scratch ... maybe it helps :)
Old 01-05-2012, 09:15 PM
Shanegrla Shanegrla is offline
You know, thanks for reminding me. That was happening to me too recently. Specifically with Mini Grand and also Battery. At the time I was in a hurry and didn't have time to look into it, but then I forgot about it. But I think if it happens again, the first thing I might try is trashing prefs. If you haven't read the Troubleshooting Tips sticky, that's one of those catch-all first-thing-to-try suggestions that does often fix a few glitches like that.
iMac 21.5" (2017) Intel Core i7 3.6GHz, 1TB SSD, 32GB RAM
PreSonus Quantum 2 interface
Mac OSX 10.15.4 Catalina
1 G-Drive Pro 4 TB
2 G-Drive 4 TB
ProTools 2019.12.0
Melodyne 4.2.4
Soundtoys Bundle 5.3.2
Omnisphere 2.6.2
Massey L2007
Superior Drummer 2.3.2
Komplete 9 Ultimate
Old 01-05-2012, 10:27 PM
AlainZagar AlainZagar is offline
Hi - Perhaps a long shot.
Do you have an "expression" pedal wired to your Midi Keyboard? This used to happen to me all the time. I would inadvertently tap this pedal and the VIs that were aware of "expression" would often drop in volume. I ended up removing the pedal and using the modulation wheel instead.
You mentioned that the volume drops even when you're not playing back. This could be the culprit.
Alain
Mini Grand issue N8ty Virtual Instruments 7 02-26-2015 08:25 PM
Mini Grand Volume Issues? StuckWithMCE Virtual Instruments 5 01-07-2011 08:20 AM
Mini Grand level can't be changed EricWillhelm Virtual Instruments 3 03-02-2010 02:25 AM
Mini Grand Level.... barstool719 Virtual Instruments 2 02-10-2009 08:51 AM
Mini Grand problem galliv Pro Tools TDM Systems (Mac) 8 01-12-2009 12:06 PM
