Old 12-23-2010, 09:16 AM
jon w jon w is offline
Question hard drive keeps ticking
I just installed Protools 8 LE on a Windows XP system. The installation seems to be OK. But the hard drive never stops ticking, as if it was reading and writing something. The program wmiprvse.exe shows some processor use. Did several restarts, but the problem persists. problem exists when Mbox is plugged in and not plugged in.
Old 12-23-2010, 09:50 AM
KingFish KingFish is offline
Default Re: hard drive keeps ticking
If you uninstall ProTools from the Add/Remove Programs... does the problem go away ?
David
- MacPro 6,1 Intel Xeon E5 2.7 GHz 12-Core 128 GB 1066 MHz DDR3
- HDX II Sonnet xMacPro Server
- 16x16 HD i/o x 6
- PT 2018.10
- OS X 10.14.4
- ProTools Dock / PT Control
Old 12-23-2010, 10:20 AM
Keybeeetsss's Avatar
Keybeeetsss Keybeeetsss is offline
Sounds like the drive may be gettin ready to R.I.P.
MYSPACE ON'EIM
LAUTEN MICS & ME
DA'TUBE ON'EIM
'IS TAMARA HOME'
NO, SHE'S WITH
HOBO KEY
'' (that dopey green thing)
('we' must start using pronouns)
Old 12-23-2010, 06:02 PM
Emcha_audio's Avatar
That sounds exactly to what my friend hdd was starting to do. He decided to make back ups of all the video editing he was doing that was stored on that drive. Sure thing enough the next day the HDD died.
Old 12-23-2010, 08:48 PM
AlainZagar AlainZagar is offline
Hi
This may sound obvious but do you have the disk space/usage window popup on screen?
That thing causes constant disk access - I suppose that's by design but I think it kind of over does it. It cycles through all my drive partitions several times a second. Not something you want happening when you're also reading and recording from the drives.
If you do, then try closing it.
Alain
Old 12-24-2010, 02:01 AM
caruso7r caruso7r is offline
Before you spend too much time troubleshooting, I strongly suggest to buy a new drive, install XP and install PT on the new drive at this point. If the current drive fails and dies, then you will have no choice but to do this anyways and if you do this now, you can save any data that might be on this drive now from this point. Usually a ticking sound indicates the drive is trying to read and/or write and the head is not reading the sector which in short means the drive is dying.
John
Pro Tools 12.5
Macbook Pro & Windows 7 Ultimate 64 Bit
DAE can't get audio from hard drive fast enough, hard drive may be fragmented, there huncke Pro Tools TDM Systems (Win) 6 02-23-2010 02:06 PM
Valid Audio Drive (hard drive issue) MacPro / HD3 owenpop Pro Tools TDM Systems (Mac) 5 01-11-2008 12:28 PM
Partition Hard Drive? Clean out G$ hard drive? ike805 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 08-23-2006 10:23 PM
Why is my LaCie external 80 gig, 7200 rpm firewire hard drive an invalid drive to be Fucius General Discussion 4 03-19-2002 11:26 PM
Hard Drive Performance Dual Processors and Dedicated Audio Drive j_jayzatuc 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 08-03-2000 05:52 PM
