Old 05-23-2011, 03:17 PM
Default Re: Xpand Freezing PT
Dot, your system specs seems fine to me anyway but if you have one out of date plug-in it will throw your whole system. Xpand!2 doesn't freeze for me but if I'm auditioning whilst playing back Pro Tools does stop playback.
Aaron Mulqueen - 001 HD Native
Old 05-23-2011, 09:34 PM
AlainZagar AlainZagar is offline
filosofem and DOT.
I don't generally have problems with my setup other than the odd XPAND2 crashing the system. It seems to be related to changing patches while either I'm in playback mode or if I'm simply just playing on the keyboard and auditioning sounds. It takes a while for it to happen so I can't say it's one patch or another. It just seems to be related to a patch change.
I can live with it because "knock on wood" I've not lost any of my work. I can save and restart and plus I really like XPAND2 a lot.
I mentioned this to DOT just in case DOT was also doing the same thing. Perhaps we can pinpoint the cause if we're using similar workflows.
(don't want to hijack his post)
DOT, I noticed you have a network printed installed. Do you have any background programs running that talk to the printer? I did and that caused me a lot of problems in the past so I removed it.
Also, you've got a wireless card. I've read posts where wireless can cause problems. Too bad windows 7 makes it so hard to manage hardware.
To reproduce the problem on my system I do one of the following
1)
- have an XPAND2 instance open with a patch selected.
- select the track so that you can play XPAND2 from the midi controller
- hit play on the transport ( or in my case - Command 8)
- advance through the patches each for about a second or two.
- at some random point in time, no more sound from the system
- system becomes unstable so quickly save and exit or just exit.
2)
- play something on the midi controller - don't hit play
or use auto patch advance feature in XPAND2
Seems to be stable until I start to change patches.
Here's my system - Note - I have RAID installed on this box but always disabled when using PT9.01. I have also resisted 9.02 due to stories about problems with grid lines disappearing. "G" drive 10K RPM VelociRaptor is audio/music drive.
SiSoftware Sandra
Computer
Model : System manufacturer System Product Name
Workgroup : WORKGROUP
Host Name : Alain-PC
User : Alain
Processor
Model : Intel(R) Core(TM) i7 CPU 920 @ 2.67GHz
Speed : 3.8GHz
Cores per Processor : 4 Unit(s)
Threads per Core : 2 Unit(s)
Type : Quad-Core
Integrated Data Cache : 4x 32kB, Synchronous, Write-Thru, 8-way, 64 byte line size, 2 threads sharing
L2 On-board Cache : 4x 256kB, ECC, Synchronous, ATC, 8-way, 64 byte line size, 2 threads sharing
L3 On-board Cache : 8MB, ECC, Synchronous, ATC, 16-way, Exclusive, 64 byte line size, 8 threads sharing
Computer
Mainboard : Asus P6T DELUXE V2
BIOS : AMI 1108 09/21/2010
Bus(es) : ISA X-Bus PCI PCIe IMB USB FireWire/1394 i2c/SMBus
Multi-Processor (MP) Support : No
Multi-Processor Advanced PIC (APIC) : Yes
Total Memory : 12GB DIMM DDR3
Chipset
Model : ASUS X58 I/O Hub
Front Side Bus Speed : 2x 3.42GHz (6.84GHz)
Chipset
Model : Intel Core Desktop (Bloomfield) UnCore
Channels : 3
Memory Bus Speed : 2x 760MHz (1.52GHz)
Memory Module(s)
Memory Module : Corsair CM3X2G1600C8D 2GB DIMM DDR3 PC3-12800U DDR3-1600 (9-9-9-24 5-34-10-5)
Video System
Video Adapter : NVIDIA GeForce GTX 470 (448 SM5.0 1.22GHz, 1.3GB, PCIe 2.00 x16)
Graphics Processor
OpenCL Processor : NVIDIA GeForce GTX 470 (448SP 14C 1.22GHz, 1.3GB)
OpenCL Processor : NVIDIA GeForce 9800 GT (112SP 14C 1.5GHz, 512MB DDR3 2x900MHz)
Compute Shader Processor : NVIDIA GeForce GTX 470 (448SP 1.22GHz, 1.3GB)
Compute Shader Processor : NVIDIA GeForce 9800 GT (112SP 1.4GHz, 512MB DDR3 2x900MHz)
CUDA Processor : NVIDIA GeForce GTX 470 (448SP 14C 1.22GHz, 1.3GB)
CUDA Processor : NVIDIA GeForce 9800 GT (112SP 14C 1.5GHz, 512MB DDR3 2x900MHz)
Storage Devices
Seagate ST31500341AS (1.5TB, SATA300, 3.5", 7200rpm, NCQ) : 1TB (H:)
Seagate ST31500341AS (1.5TB, SATA300, 3.5", 7200rpm, NCQ) : 1TB (I:)
Seagate ST32000641AS (2TB, SATA600, 3.5", 7200rpm, NCQ) : 2TB (C:) (D:) (E:) (F:)
Seagate ST31000333AS (1TB, SATA300, 3.5", 7200rpm, NCQ) : 932GB (Q:)
WDC WD3000HLFS-01G6U0 (300GB, SATA300, 3.5", 10000rpm, NCQ, 16MB Cache) : 279GB (G:)
Seagate ST3500630A (500.1GB, ATA, 3.5", NCQ) : 466GB (K:)
Seagate ST3500630A (500.1GB, ATA, 3.5", NCQ) : 466GB (L:)
Generic STORAGE DEVICE (USB) : N/A (U:)
Generic STORAGE DEVICE (USB) : N/A (V:)
Generic STORAGE DEVICE (USB) : N/A (W:)
Generic STORAGE DEVICE (USB) : N/A (X:)
ATAPI iHBS212 2 (SATA150, BD-RW, DVD+-RW, CD-RW, 8MB Cache) : N/A (M:)
HL-DT-STDVDRAM GE20LU10 (USB) : N/A (Z:)
Logical Storage Devices
03_Video (H:) : 1TB (NTFS) @ Seagate ST31500341AS (1.5TB, SATA300, 3.5", 7200rpm, NCQ)
04_IMAGES (I:) : 1TB (NTFS) @ Seagate ST31500341AS (1.5TB, SATA300, 3.5", 7200rpm, NCQ)
00_XBoot (D:) : 100GB (NTFS) @ Seagate ST32000641AS (2TB, SATA600, 3.5", 7200rpm, NCQ)
05_Dock (Q:) : 932GB (NTFS) @ Seagate ST31000333AS (1TB, SATA300, 3.5", 7200rpm, NCQ)
02_Music (G:) : 279GB (NTFS) @ WDC WD3000HLFS-01G6U0 (300GB, SATA300, 3.5", 10000rpm, NCQ, 16MB Cache)
00_Data (E:) : 101GB (NTFS) @ Seagate ST32000641AS (2TB, SATA600, 3.5", 7200rpm, NCQ)
00_Vid (F:) : 1TB (NTFS) @ Seagate ST32000641AS (2TB, SATA600, 3.5", 7200rpm, NCQ)
06_Photos (K:) : 466GB (NTFS) @ Seagate ST3500630A (500.1GB, ATA, 3.5", NCQ)
07_Spare2 (L:) : 466GB (NTFS) @ Seagate ST3500630A (500.1GB, ATA, 3.5", NCQ)
00_Boot (C:) : 300GB (NTFS) @ Seagate ST32000641AS (2TB, SATA600, 3.5", 7200rpm, NCQ)
Removable Drive (U:) : N/A @ Generic STORAGE DEVICE (USB)
Removable Drive (V:) : N/A @ Generic STORAGE DEVICE (USB)
Removable Drive (W:) : N/A @ Generic STORAGE DEVICE (USB)
Removable Drive (X:) : N/A @ Generic STORAGE DEVICE (USB)
Optical Drive (M:) : N/A @ ATAPI iHBS212 2 (SATA150, BD-RW, DVD+-RW, CD-RW, 8MB Cache)
Optical Drive (Z:) : N/A @ HL-DT-STDVDRAM GE20LU10 (USB)
Peripherals
LPC Hub Controller 1 : ASUS LPC Interface Controller
LPC Legacy Controller 1 : T0 A5-13
Audio Device : ASUS HD Audio Controller
Audio Device : EVGA GF100 High Definition Audio Controller
Audio Codec : nVidia Mutara V08 [NV2]
Audio Codec : 1 0001h
Disk Controller : ASUS 6 port SATA AHCI Controller
USB Controller 1 : ASUS USB UHCI Controller #4
USB Controller 2 : ASUS USB UHCI Controller #5
USB Controller 3 : ASUS USB UHCI Controller #6
USB Controller 4 : ASUS USB EHCI Controller #2
USB Controller 5 : ASUS USB UHCI Controller #1
USB Controller 6 : ASUS USB UHCI Controller #2
USB Controller 7 : ASUS USB UHCI Controller #3
USB Controller 8 : ASUS USB EHCI Controller #1
FireWire/1394 Controller 1 : TI TSB43AB23 1394a-2000 OHCI PHY/link-layer Controller
SMBus/i2c Controller 1 : Intel 801xx/63xx SMBus
Printers and Faxes
Printer : Brother QL-570 (300x600, USB)
Printer : Brother HL-2070N series (1200x1200)
Printer : Adobe PDF Converter (4000x4000, Colour)
Scanners and Cameras
Scanner : EPSON Perfection 2480/2580 (Scanner, 2400x2400, USB)
Peripherals
Media Player : ()
Media Player : ()
Media Player : ()
Media Player : ()
Network Services
Network Adapter : Marvell Yukon 88E8056 PCI-E Gigabit Ethernet Controller (Ethernet, 100Mbps)
Network Adapter : Marvell Yukon 88E8056 PCI-E Gigabit Ethernet Controller #2 (Ethernet, 1Gbps)
Power Management
Mains (AC) Line Status : On-Line
Operating System
Windows System : Microsoft Windows 7 Ultimate 6.01.7601 (Service Pack 1)
Platform Compliance : x64
Windows Experience Index
Current System : 5.9
Old 05-23-2011, 10:13 PM
Alain, I can not reproduce this issue. It is more than likely that this issue is pointing more towards your system. Maybe not in hardware respects, cause your rig is the same if not better than mine and current. Ummm... can you post a sandra report of your plug-ins please?
Old 05-24-2011, 12:03 AM
Dot Dot is offline
just ran 3 hour session using xpand2, was changing patches, sequencing and doung pretty much all... and no issue at all. It worked perfectly fine today I'm really not sure what could be the reason for "crash" last week it was happening too often, but now i can't complain at all (at least today)
www.dominicdotokune.com
Old 05-24-2011, 09:24 PM
DOT - same here tonight. No crashing and I really tried to push the system to the limit too. At one point had RTAS usage up to 45% with a dozen VIs.
filosofem,
I managed to get the tech support utility to cough up the version numbers for the plug-ins - not easy to do in PT9. I couldn't find a copy of "trasher" to download - by some accounts it seems to be able to report version numbers.
I'm not sure what I'm looking for as it's really hard to find out what the latest version should be for the plugins from some manufactures. Some appear to report back incorrectly - ie. Addictive Drums - I know it's V1.5.2.
Line 6 - who knows?
Plug-In Version List
started: Tue May 24 22-46-32 2011
Plug-In: Version:
C:\Program Files\Common Files\Digidesign\DAE\Plug-Ins\
.. Not Available
Addictive Drums.dpm ----------------1.5.1.23
Addictive Drums.dpm.rsr ------------Not Available
AIRChorus.dpm ----------------------1.0.2.10105
AIRChorus.dpm.rsr ------------------Not Available
AIRDistortion.dpm ------------------1.0.2.10105
AIRDistortion.dpm.rsr --------------Not Available
AIRDynamicDelay.dpm ----------------1.0.2.10105
AIRDynamicDelay.dpm.rsr ------------Not Available
AIREnhancer.dpm --------------------1.0.2.10105
AIREnhancer.dpm.rsr ----------------Not Available
AIREnsemble.dpm --------------------1.0.2.10105
AIREnsemble.dpm.rsr ----------------Not Available
AIRFilterGate.dpm ------------------1.0.2.10105
AIRFilterGate.dpm.rsr --------------Not Available
AIRFlanger.dpm ---------------------1.0.2.10105
AIRFlanger.dpm.rsr -----------------Not Available
AIRFrequencyShifter.dpm ------------1.0.2.10105
AIRFrequencyShifter.dpm.rsr --------Not Available
AIRFuzz-Wah.dpm --------------------1.0.2.10105
AIRFuzz-Wah.dpm.rsr ----------------Not Available
AIRKillEQ.dpm ----------------------1.0.2.10105
AIRKillEQ.dpm.rsr ------------------Not Available
AIRLo-Fi.dpm -----------------------1.0.2.10105
AIRLo-Fi.dpm.rsr -------------------Not Available
AIRMulti-Chorus.dpm ----------------1.0.2.10105
AIRMulti-Chorus.dpm.rsr ------------Not Available
AIRMulti-Delay.dpm -----------------1.0.2.10105
AIRMulti-Delay.dpm.rsr -------------Not Available
AIRNon-LinearReverb.dpm ------------1.0.2.10105
AIRNon-LinearReverb.dpm.rsr --------Not Available
AIRPhaser.dpm ----------------------1.0.2.10105
AIRPhaser.dpm.rsr ------------------Not Available
AIRReverb.dpm ----------------------1.0.2.10105
AIRReverb.dpm.rsr ------------------Not Available
AIRSpringReverb.dpm ----------------1.0.2.10105
AIRSpringReverb.dpm.rsr ------------Not Available
AIRStereoWidth.dpm -----------------1.0.2.10105
AIRStereoWidth.dpm.rsr -------------Not Available
AIRTalkbox.dpm ---------------------1.0.2.10105
AIRTalkbox.dpm.rsr -----------------Not Available
AIRVintageFilter.dpm ---------------1.0.2.10105
AIRVintageFilter.dpm.rsr -----------Not Available
ARIA Player RTAS_x86.dpm -----------8.0.4.1
BF Essential Clip Remover.dpm ------8.0.0.314
BF Essential Clip Remover.dpm.rsr --Not Available
BF Essential Correlation.dpm -------8.0.0.314
BF Essential Correlation.dpm.rsr ---Not Available
BF Essential Meter Bridge.dpm ------8.0.0.314
BF Essential Meter Bridge.dpm.rsr --Not Available
BF Essential Noise Meter.dpm -------8.0.0.314
BF Essential Noise Meter.dpm.rsr ---Not Available
BitterSweetII.dpm ------------------2.2.0.7094
BitterSweetII.dpm.rsr --------------Not Available
bombfactory BF76.dpm ---------------8.0.0.314
bombfactory BF76.dpm.rsr -----------Not Available
Boom.dpm ---------------------------1.0.2.10105
Boom.dpm.rsr -----------------------Not Available
Chorus.dpm -------------------------8.0.0.314
Chorus.dpm.rsr ---------------------Not Available
Click.dpm --------------------------8.0.0.314
Click.dpm.rsr ----------------------Not Available
D-Verb.dpm -------------------------8.0.0.314
D-Verb.dpm.rsr ---------------------Not Available
DB-33.dpm --------------------------1.0.2.10105
DB-33.dpm.rsr ----------------------Not Available
DigiReWire.dpm ---------------------9.0.1.41
DigiReWire.dpm.rsr -----------------Not Available
Dither.dpm -------------------------8.0.0.314
Dither.dpm.rsr ---------------------Not Available
Dynamics III.dpm -------------------8.0.0.314
Dynamics III.dpm.rsr ---------------Not Available
Elastic Audio.dpm ------------------9.0.1.41
Elastic Audio.dpm.rsr --------------Not Available
Eleven Delay UI.dpm ----------------Not Available
Eleven Delay UI.dpm.rsr ------------Not Available
Eleven Distortion UI.dpm -----------Not Available
Eleven Distortion UI.dpm.rsr -------Not Available
Eleven Dynamics UI.dpm -------------Not Available
Eleven Dynamics UI.dpm.rsr ---------Not Available
Eleven EQ UI.dpm -------------------Not Available
Eleven EQ UI.dpm.rsr ---------------Not Available
Eleven Free.dpm --------------------8.0.0.314
Eleven Free.dpm.rsr ----------------Not Available
Eleven FX Loop UI.dpm --------------Not Available
Eleven FX Loop UI.dpm.rsr ----------Not Available
Eleven Modulation UI.dpm -----------Not Available
Eleven Modulation UI.dpm.rsr -------Not Available
Eleven Reverb UI.dpm ---------------Not Available
Eleven Reverb UI.dpm.rsr -----------Not Available
Eleven Tuner UI.dpm ----------------Not Available
Eleven Tuner UI.dpm.rsr ------------Not Available
Eleven UI.dpm ----------------------8.0.4.994
Eleven UI.dpm.rsr ------------------Not Available
Eleven Volume UI.dpm ---------------Not Available
Eleven Volume UI.dpm.rsr -----------Not Available
Eleven Wah UI.dpm ------------------Not Available
Eleven Wah UI.dpm.rsr --------------Not Available
EQ III.dpm -------------------------8.0.0.314
EQ III.dpm.rsr ---------------------Not Available
Flanger.dpm ------------------------8.0.0.314
Flanger.dpm.rsr --------------------Not Available
Hybrid -----------------------------Not Available
Hybrid.dpm -------------------------1.6.0.9474
Hybrid.dpm.rsr ---------------------Not Available
Invert-Duplicate.dpm ---------------8.0.0.314
Invert-Duplicate.dpm.rsr -----------Not Available
iZotope_Radius_Win32.dll -----------1.0.0.439
Kontakt 4.dpm ----------------------4.2.3.4914
Line 6 -----------------------------Not Available
LoFi.dpm ---------------------------8.0.0.314
LoFi.dpm.rsr -----------------------Not Available
Maxim.dpm --------------------------8.0.0.314
Maxim.dpm.rsr ----------------------Not Available
Melodyne.dpm -----------------------1.2.1.12
Melodyne.dpm.rsr -------------------Not Available
MiniGrand.dpm ----------------------1.0.2.10105
MiniGrand.dpm.rsr ------------------Not Available
Mod Delay II.dpm -------------------8.0.0.314
Mod Delay II.dpm.rsr ---------------Not Available
Multi-Tap Delay.dpm ----------------8.0.0.314
Multi-Tap Delay.dpm.rsr ------------Not Available
Normalize-Gain Change.dpm ----------8.0.0.314
Normalize-Gain Change.dpm.rsr ------Not Available
Philharmonik.dpm -------------------0.0.0.0
Philharmonik.dpm.rsr ---------------Not Available
Philharmonik.ini -------------------Not Available
Ping-Pong Delay.dpm ----------------8.0.0.314
Ping-Pong Delay.dpm.rsr ------------Not Available
Pitch.dpm --------------------------8.0.0.314
Pitch.dpm.rsr ----------------------Not Available
RectiFi.dpm ------------------------8.0.0.314
RectiFi.dpm.rsr --------------------Not Available
Reverse-DC Removal.dpm -------------8.0.0.314
Reverse-DC Removal.dpm.rsr ---------Not Available
SansAmp PSA-1.dpm ------------------8.0.0.314
SansAmp PSA-1.dpm.rsr --------------Not Available
SciFi.dpm --------------------------8.0.0.314
SciFi.dpm.rsr ----------------------Not Available
Signal Generator.dpm ---------------8.0.0.314
Signal Generator.dpm.rsr -----------Not Available
SignalTools.dpm --------------------8.0.0.314
SignalTools.dpm.rsr ----------------Not Available
Structure.dpm ----------------------1.0.5.10611
Structure.dpm.rsr ------------------Not Available
STTool.dpm -------------------------2.2.0.7094
STTool.dpm.rsr ---------------------Not Available
Surround Mixer.dpm -----------------9.0.1.41
Surround Mixer.dpm.rsr -------------Not Available
Time Comp-Exp-Pitch Shift.dpm ------8.0.0.314
Time Comp-Exp-Pitch Shift.dpm.rsr --Not Available
Time Shift.dpm ---------------------8.0.1.510
Time Shift.dpm.rsr -----------------Not Available
TimeAdjuster.dpm -------------------8.0.0.314
TimeAdjuster.dpm.rsr ---------------Not Available
TL AutoPan.dpm ---------------------8.0.0.314
TL AutoPan.dpm.rsr -----------------Not Available
TL InTune.dpm ----------------------8.0.0.314
TL InTune.dpm.rsr ------------------Not Available
TL Master Meter.dpm ----------------8.0.0.314
TL Master Meter.dpm.rsr ------------Not Available
TL Metro.dpm -----------------------8.0.0.314
TL Metro.dpm.rsr -------------------Not Available
Trim.dpm ---------------------------8.0.0.314
Trim.dpm.rsr -----------------------Not Available
Vacuum.dpm -------------------------1.0.2.10105
Vacuum.dpm.rsr ---------------------Not Available
VariFi.dpm -------------------------8.0.0.314
VariFi.dpm.rsr ---------------------Not Available
Xpand!.dpm -------------------------2.0.2.10105
Xpand!.dpm.rsr ---------------------Not Available
End Directory: C:\Program Files\Common Files\Digidesign\DAE\Plug-Ins
C:\Program Files\Common Files\Digidesign\DAE\Plug-Ins (Unused)\
.. Not Available
BF Essential Tuner.dpm -------------8.0.0.314
BF Essential Tuner.dpm.rsr ---------Not Available
Dynamics II.dpm --------------------8.0.0.314
Dynamics II.dpm.rsr ----------------Not Available
EQ II.dpm --------------------------8.0.0.314
EQ II.dpm.rsr ----------------------Not Available
Funk Logic Mastererizer.dpm --------8.0.0.314
Funk Logic Mastererizer.dpm.rsr ----Not Available
Stereo Dithered Mixer.dpm ----------9.0.1.41
Stereo Dithered Mixer.dpm.rsr ------Not Available
Stereo Mixer.dpm -------------------9.0.1.41
Stereo Mixer.dpm.rsr ---------------Not Available
Surround Dithered Mixer.dpm --------9.0.1.41
Surround Dithered Mixer.dpm.rsr ----Not Available
End Directory: C:\Program Files\Common Files\Digidesign\DAE\Plug-Ins (Unused)
C:\Program Files\Digidesign\Pro Tools\
.. Not Available
AAFCOAPI.dll -----------------------1.1.6.6995
AFnd.dll ---------------------------9.0.1.41
asifont.map ------------------------Not Available
Asiport.rsr ------------------------Not Available
BUI.dll ----------------------------9.0.1.41
BUI_Resource404.dll ----------------9.0.1.41
BUI_Resource411.dll ----------------9.0.1.41
BUI_Resource412.dll ----------------9.0.1.41
BUI_Resource804.dll ----------------9.0.1.41
Cfd.dll ----------------------------9.0.1.41
CFD.idb ----------------------------Not Available
CFD.vdb ----------------------------Not Available
Cfd_Resource404.dll ----------------9.0.1.41
Cfd_Resource411.dll ----------------9.0.1.41
Cfd_Resource412.dll ----------------9.0.1.41
Cfd_Resource804.dll ----------------9.0.1.41
CFnd.dll ---------------------------9.0.1.41
CFnd_Resource404.dll ---------------9.0.1.41
CFnd_Resource411.dll ---------------9.0.1.41
CFnd_Resource412.dll ---------------9.0.1.41
CFnd_Resource804.dll ---------------9.0.1.41
DAE.dll ----------------------------9.0.1.41
DAE.dll.rsr ------------------------Not Available
DAE_Resource404.dll ----------------9.0.1.41
DAE_Resource411.dll ----------------9.0.1.41
DAE_Resource412.dll ----------------9.0.1.41
DAE_Resource804.dll ----------------9.0.1.41
Databases --------------------------Not Available
DFW.dll ----------------------------9.0.1.41
DFW.idb ----------------------------Not Available
DFW.vdb ----------------------------Not Available
DFW_KeyHook.dll --------------------9.0.1.41
DFW_Resource404.dll ----------------9.0.1.41
DFW_Resource411.dll ----------------9.0.1.41
DFW_Resource412.dll ----------------9.0.1.41
DFW_Resource804.dll ----------------9.0.1.41
DHS.dll ----------------------------9.0.1.41
DHS.idb ----------------------------Not Available
DHS.vdb ----------------------------Not Available
DHS_Resource404.dll ----------------9.0.1.41
DHS_Resource411.dll ----------------9.0.1.41
DHS_Resource412.dll ----------------9.0.1.41
DHS_Resource804.dll ----------------9.0.1.41
DigiExt.dll ------------------------9.0.1.41
DigiMIDI.dll -----------------------9.0.1.41
DigiMIDIServices.dll ---------------9.0.1.41
DigiMIDI_Resource404.dll -----------9.0.1.41
DigiMIDI_Resource411.dll -----------9.0.1.41
DigiMIDI_Resource412.dll -----------9.0.1.41
DigiMIDI_Resource804.dll -----------9.0.1.41
DigiPlatformSupport.dll ------------9.0.1.41
DigiRefClock.dll -------------------9.0.1.41
DigiReg.file -----------------------Not Available
digiSPTIService.exe ----------------9.0.1.41
DigiSyncReader.dll -----------------9.0.1.41
DigiVout.qtr -----------------------Not Available
DigiVout.qtx -----------------------Not Available
DirectIO.dll -----------------------9.0.1.41
DMC.dll ----------------------------9.0.1.41
DSI.dll ----------------------------9.0.1.41
DSPManager.dll ---------------------9.0.1.41
DUI.dll ----------------------------9.0.1.41
DUI.idb ----------------------------Not Available
DUI.vdb ----------------------------Not Available
DUI_Resource404.dll ----------------9.0.1.41
DUI_Resource411.dll ----------------9.0.1.41
DUI_Resource412.dll ----------------9.0.1.41
DUI_Resource804.dll ----------------9.0.1.41
FFmt.dll ---------------------------9.0.1.41
FFmt_Resource404.dll ---------------9.0.1.41
FFmt_Resource411.dll ---------------9.0.1.41
FFmt_Resource412.dll ---------------9.0.1.41
FFmt_Resource804.dll ---------------9.0.1.41
GDIPlusWrapper.dll -----------------Not Available
Grooves ----------------------------Not Available
Gtr.dll ----------------------------9.0.1.41
Gtr_Resource404.dll ----------------9.0.1.41
Gtr_Resource411.dll ----------------9.0.1.41
Gtr_Resource412.dll ----------------9.0.1.41
Gtr_Resource804.dll ----------------9.0.1.41
LGC.dll ----------------------------9.0.1.41
MMERefresh.exe ---------------------9.0.1.41
NeoAccess.dll ----------------------9.0.1.41
NTL.dll ----------------------------Not Available
OMFToolkit.dll ---------------------9.0.1.41
Plug-Ins.lnk -----------------------Not Available
Pro Tools Registration.exe ---------0.1.0.11
Pro Tools Utilities ----------------Not Available
ProTools.cat -----------------------Not Available
ProTools.digitrace -----------------Not Available
ProTools.dll -----------------------9.0.1.41
ProTools.exe -----------------------9.0.1.41
ProTools.idb -----------------------Not Available
PROTOOLS.RSR -----------------------Not Available
ProTools.vdb -----------------------Not Available
ProToolsApp.idb --------------------Not Available
ProToolsApp.vdb --------------------Not Available
ProToolsApp_Resource404.dll --------9.0.1.41
ProToolsApp_Resource411.dll --------9.0.1.41
ProToolsApp_Resource412.dll --------9.0.1.41
ProToolsApp_Resource804.dll --------9.0.1.41
ProToolsNative_FW_d400.bin ---------Not Available
ProToolsNative_FW_d410.bin ---------Not Available
ProToolsNative_FW_d411.bin ---------Not Available
ProTools_Resource404.dll -----------9.0.1.41
ProTools_Resource411.dll -----------9.0.1.41
ProTools_Resource412.dll -----------9.0.1.41
ProTools_Resource804.dll -----------9.0.1.41
PTHelp -----------------------------Not Available
RTEngineDiag.dll -------------------9.0.1.41
Session Templates ------------------Not Available
Sib.dll ----------------------------9.0.1.41
Sib_Resource404.dll ----------------Not Available
Sib_Resource411.dll ----------------Not Available
Sib_Resource412.dll ----------------Not Available
Sib_Resource804.dll ----------------Not Available
SoftwareUpdater.exe ----------------9.0.1.41
SoftwareUpdater_Resource404.dll ----9.0.1.41
SoftwareUpdater_Resource411.dll ----9.0.1.41
SoftwareUpdater_Resource412.dll ----9.0.1.41
SoftwareUpdater_Resource804.dll ----9.0.1.41
StreamManager.dll ------------------8.0.3.251
SystemLink.dll ---------------------9.0.1.41
TCPE.dll ---------------------------9.0.1.41
Trns.dll ---------------------------Not Available
updater-version.properties ---------Not Available
VenueLink.dll ----------------------Not Available
xerces-c_2_6.dll -------------------2.5.0.0
End Directory: C:\Program Files\Digidesign\Pro Tools
C:\Program Files\Digidesign\DAE\
Find Function returned no results for directory: C:\Program Files\Digidesign\DAE\*
Old 05-25-2011, 02:33 PM
Alain, you know you are going to have to spend the time checking whether those plug-ins are up to date. From the plug-ins that I use they seem to be fine but I don't have all that is on that list.
Currently, I think this is the only thread I know of that contains this issue. Two, maybe three users out of thousands have a problem. It is more than likely it is a user problem based on their system in some form and you'll need to troubleshoot.
[IMG] code is Off
Pro Tools 10 freezing, XPand missing [installed on SSD w/ OS] avryluy Windows 2 03-01-2014 08:07 AM
Pro tools SLOW, and Freezing then continuing, then freezing again DJX-RAY 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 05-09-2011 07:52 AM
PT LE 8.04 freezing on loading soft synth (xpand!, hybrid, etc..), after computer upg microbang 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 11-30-2010 10:53 AM
Xpand can't find the Xpand.dat mountainman 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 01-12-2009 12:24 AM
Xpand.dat Gone/Xpand Crashes PT 7.4 dts.music Virtual Instruments 2 09-16-2008 09:00 PM
