Old 11-30-2010, 10:57 PM
application4 application4 is offline
Default White Noise on PT 8.1 mac session import
Here's what's happening:
I'm opening a session on my W7 (64bit) HD2 rig running PT 8.1 cs2. (I know... 64bit is still in beta...)
The session was created on a Intel Mac running PT HD 8.1.
Waveforms display correctly but all the audio tracks output loud white noise.
Other sessions on the same drive open and run fine.
If I audition the audio files in the audio import window they play back fine, and if I audition them in W7 preview player they're fine too.
Have tried 'import session data' and importing the files into a fresh blank session. Same problem occurs.
The audio files import fine into Ableton Live running stand alone and playback with no problems.
Any thoughts?
Thanks.
Old 12-05-2010, 11:23 AM
avasound avasound is offline
Default Re: White Noise on PT 8.1 mac session import
Hi!
Simply open session and SAVE COPY IN...with copy all audio files. Then open new session and all be OK!
Old 12-06-2010, 05:10 PM
Thanks for the tip but I've tried that I'm afraid, and the same problem occurred.
I gave up and opened the audio in Ableton Live which worked perfectly...
Weird.
white noise with just open session help! papitopinillo Windows 2 09-24-2012 08:38 PM
LOUD White noise every 15 seconds upon session load.. (before any playback or rec) awritersparadise Pro Tools 9 5 04-28-2011 06:51 PM
FCP OMF import into PT9 is white noise EverettMarshall macOS 1 04-13-2011 12:55 PM
OMF Import from Logic = White Noise! Sonic Nomad Pro Tools 9 5 11-22-2010 06:14 AM
import audio and only get white noise Kris75 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 09-20-2002 04:21 PM
