PT 7.0 crashes when I load a particular session
all,
i started writing a song all in midi about 2 months ago and now for some reason when i go to open the file, pro tools crashes. PT launches just fine with any other session. any idea why this could be happening and how i can fix it...if at all? thanks! `kris |
Re: PT 7.0 crashes when I load a particular session
I've had some sessions get corrupted from time to time, what i usually do is go to Import session information select all the tracks and copy all the files. if that doesn't work i start doing one track at a time incase something is continuing to crash the session(bad plugin corrupt file...)
Good Luck |
Your files probably got corrupted. Just go to your back up files. You should be making a backup every time you finish working on a session in a day or more if you made a lot of changes. Keep several versions of backups so you can always go back to the last few backup as needed. You did make a backup right? (Do not answer, it's a rhetorical question).
Obsidian Dragon
MacbookPro14,3 - Intel Core i7 3.1 GHz, 16 GB MacOS 13.6.6 running Protools 2024.3.1 Mac Studio M1Max - 64GB MacOS 14.4.1 running Protools 2024.3.1 |
protools 11.01 close session crashes on load next session | eddie lamb | Pro Tools 11 | 2 | 09-07-2013 01:51 AM |
Pro Tools LE 8 crashes when trying to load new or existing session | jgerards | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 01-07-2011 08:26 AM |
Win 7, PT 8.0.3 Crashes on session load | tanona | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 01-05-2010 12:57 PM |
Analog Factory crashes PT 8cs3 on session load | DrFord | Pro Tools TDM Systems (Mac) | 4 | 09-11-2009 02:29 PM |
pro tools le 7.3.1 cs 5 session load up crashes | streetcorna | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 12-14-2007 06:03 AM |
