Old 07-12-2018, 09:34 AM
risey's Avatar
risey risey is offline
Default Session Hangs on load / crashes /
Have a weird problem, when loading a session and during plugins loading PT hangs then crashes. So my next step was to find which plugin is causing it, I held down SHIFT (windows 10) on load and the session loaded fine. I then began making each plugin active until the session crashed, but the problem is it is random, one second its the built in PT 1 Band EQ, next second its suboom bass, next second its Reveal Sound Spire, there is no pattern to what is causing the crash?
Anyone having similar problems?
Cheers
Ryan
http://www.PhatMonkey.me
Windows 10 64bit | Asus Rog Maximus X Formula Z370 | Intel i7-8700K CPU @3.70GHz, 3696 Mhz 6 Core(s) 12 Logical Processor(s) | Corsair LPX Vengeance 64g DDR4 RAM | Avid Mbox Pro 3 | Focusrite 18i20 2nd Gen | MSI GTX 1080TI Gaming X Trio | Acer Z35 Predator Monitor
Old 07-12-2018, 11:14 AM
risey's Avatar
Default Re: Session Hangs on load / crashes /
UPDATE: At first I thought SPIRE was at fault as I had 3 versions of the plugin, but it seems that is not the case, there is no pattern to which plugin is causing the hang, I found a way around it, but it is annoying, I have to load the session with plugins disabled, then duplicate all channels that have a synth on them and delete the original, I then save it and reopen within the session and that works, I have to do this each time. I have reinstalled Pro Tools, trashed setting and all sorts.... this is a PT problem because if it were a plugin why is it random, for example it may crash on loading spire, then delete spire then its exhale, delete exhale then its avenger....
needs to be reported to the devs...
protools 11.01 close session crashes on load next session eddie lamb Pro Tools 11 2 09-07-2013 01:51 AM
help! upgraded to snow lep...transfuser hangs pt on session load... regis Pro Tools TDM Systems (Mac) 1 11-29-2010 02:12 AM
Win 7, PT 8.0.3 Crashes on session load tanona 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 01-05-2010 12:57 PM
pro tools le 7.3.1 cs 5 session load up crashes streetcorna 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 12-14-2007 06:03 AM
PT 7.0 crashes when I load a particular session phentalmyst 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 08-08-2006 11:58 PM
