Old 03-11-2019, 06:03 AM
reichman's Avatar
reichman reichman is offline
Default Suspend All Groups paranoia
After completing a long and mission-critical re-record, I looked down and noticed that I was in "suspend all groups" (cmd-shift-g) mode. Everything sounded fine, but afterwards I was paranoid that maybe it wasn't an accurate playback.
Is there any reason a PT session would sound different in suspend? The VCAs keep working, all tracks keep reading automation... right?
Nathaniel Reichman
Producer/Re-recording Mixer - New York
Nathaniel Reichman | IMDB | LinkedIn
Old 03-11-2019, 06:11 AM
henningaround henningaround is offline
Default Re: Suspend All Groups paranoia
As long as you don't group tracks and their inserts and/or sends... but that only effects recording automation. Playback is fine. And it makes a difference with edit groups but I think you would have recognized that :)
Old 03-11-2019, 09:16 AM
BScout BScout is offline
Playback will always be fine in suspend (since it really only affects while writing groups)
And, of course, VCA groups ignore group suspend.
So if you use groups only for VCA, it will always be fine. If you are editing/writing automation, it only needs to be on while actually editing/writing automation.
Old 03-11-2019, 10:32 AM
reichman's Avatar
Thanks BScout. It all sounded fine, and the mix moves I had to make weren't dependent on an active group. Paranoia averted!
Nathaniel Reichman
HTML code is On
Better key command for suspend all groups? spenedit Pro Tools 12 19 10-20-2015 04:49 AM
Way to temporally suspend VCA groups/auto? postprosound Post - Surround - Video 4 02-10-2011 05:14 PM
Suspend Groups command-where is it? hybridd Pro Tools M-Powered (Mac) 1 11-29-2007 04:51 AM
110-240 Paranoia CPettigrew Pro Tools TDM Systems (Mac) 3 08-27-2005 11:02 PM
Satic noise paranoïa and Powerbooks minuaño General Discussion 2 04-06-2005 02:01 AM
